Home | Samsung | HLN617W 61 in. Rear Projection HDTV Tel... | I bought a SAMSUNG mod...
Samsung HLN617W 61 in. Rear Projection HDTV Television
Problem for Samsung HLN617W 61 in. Rear Projection HDTV Television
I bought a SAMSUNG model HLN617W from the thrift
By mojo_man1200 on Nov 08, 2009
I bought a SAMSUNG model HLN617W from the thrift store and everything seems to be working fine except for an annoying buzzing sound that appears to be coming from the rear bottom right side near the lamp. What could this be?
Solution #1
posted on Nov 08, 2009
Not Rated)
mikadot
Rank: Wiz
Rating: 82%, 35 votes
i had a tv of mine make an annoying ringing sound    I found it to be a fixed coil that was supposed to be held still with hot glue    if i touched it with the plastic end of a screwdriver the sound went away    you may have to take the tv apart and touch components one by one with a plastic device to try to locate the noisy part
Was this helpful?
Yes
No
Popular Solutions for Samsung HLN617W 61 in. Rear
Questions and Unsolved Problems for Samsung HLN617W 61 in. Rear
Do you recommend Samsung HLN617W 61 in. Rear Projection HDTV Television?
Answer
Answer
Wont come on...it cycles 3 times and then the standby light comes on.
Answer
It is powering itself off.. It will turn back on ,but turns off again in a few minutes
Answer
have a 63" dlp model HLN617W and its making a grinding noise it turns on then shuts itself off... (More)
Answer
samsung flat screen keeps turning off...sound stays on...what is the problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung HLN617W 61 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
