Describe your biostar p4m800-m7a cpu overheats Problem -- CPU runs ~65 degrees with case open. Machine shuts off w/o warning when case is closed, even though CPU cooler fan is exhausted and a 2nd exhaust fan is also installed
Open your computer BIOS. To do this press F8 when start-up and then once your in the BIOS settings, enter power management section and then look for any settings there relating to temperature automatic shutdown. Save changes and restart computer. If it doesn't solve the problem. Reset your motherboard BIOS to do this, open your computer casing and then look for the BIOS jumper setting, it should be near the CMOS battery. Refer also to the motherboard manual to do this. Hope this could help..Please don't forget to rate me..:-) Thanks..
When using 'esata' it hangs at the bios post screen. "It has already detected my IDE drives. It...
(More)
When using 'esata' it hangs at the bios post screen. "It has already detected my IDE drives. It then says detecting IDE drives again. Which it actually checks my sata drives. It hangs after saying that. Unplug it and it's fine USB 2.0 is also fine. Connections and cables are fine aswell Whats going on.
I have foxconn G31MX 2.0 motherboard. it seems that microphone is not working from front panel as...
(More)
I have foxconn G31MX 2.0 motherboard. it seems that microphone is not working from front panel as well as from back.... why is that.. i have user manual. but i couldn't find a way to a solution...
Am inlocuit bateria de pe placa de baza cu una mai slaba si nu se mai incarca sistemul de operare....
(More)
Am inlocuit bateria de pe placa de baza cu una mai slaba si nu se mai incarca sistemul de operare. Sa fie din cauza bateriei?
