Question about Philips FW-R7 CD Shelf System
Insert disk indicator problem
I have successfully used my system for several years now and have been very happy with it. Recently, when recording some CDs, the recorder stopped recognizing disks that were loaded into it. The CDs are the correct ones (I had been using Memorex music CDs successfully) I know that I've loaded the disk correctly (label side up) and I've not moved the machine at all from where I had it when it was successfully recording. Does anyone have any other suggestions? Could the lens stop working? Is it worth it to replace it?
  • tinyf Apr 22, 2008
    I have the same problem about the recorder not recognising that a disk has been inserted. According to my repair shop, apparently a Philips specialist, Philips won't provide an upgrade to the program that would have rectified the problem.
  • 319 Answers
Unit may have defective disk motor or optical pick-up. There is a chance the lens on pick-up may need cleanning. If you can reach it, try gently useing a q-tip in a circular motion on lens
Posted on May 07, 2008
I recently had my Gateway ML6721 freeze up and was asking to insert OEM supplied disk for repair. Repair didn't work was looking for missing drivers. Attempted several times to do a repair with no success...
You don't ! Get the model of your hard drive and go to the manafacturers Web Site. There you will probably find a sofware utility that will format and partition the disc for you. No other Computer ? Use a Friends !
Aug 24, 2009 | Computers & Internet
Recently, i;ve been trying to record tv programs on my Panasonic DVD Video Recorder DMR-E50, as i have done so for many years. However, lately, whenever i program it to record a tv program using the timer...
Hi Leah,
Good description and good job in narrowing down the problem. The lens is the remaining common denominator.
You need to get a CD/DVD lens cleaner. It should have a disk and a bottle of cleaning solution. They are available in the electronics dept of most chain stores.
A couple drops of cleaning solution on the feathery cleaning element attached to the disk, insert the disk into the machine and hit play. Takes just a couple seconds.
Best regards
Aug 17, 2009 | Panasonic DMR-E50 DVD Recorder
Disc indicates "disc full" after only a couple minutes of recordi
Brand of disk or bad laser alignment can cause this. if you have changed brands of disks go back to the others and if you have not then laser alignment is the most likely cause and can be fixed by a certified technician in this field.
Dec 26, 2008 | Philips CDR770 CD Recorder
Dvd recorder formatting problem
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
Open up 'My Computer'. You should see it under the list of available drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine
May 20, 2008 | Panasonic DMRES15 DVD Recorder
Records when it wants to
im think that you have no battery problem! because you're unit have a trouble.
Apr 18, 2008 | Cyberhome DVR 1600 DVD Recorder
DVD won't recognize the disk message below
Try running a DVD cleaner through it and see what happens. You can get one at Walmart for under $10. If that doesn't do the trick then take it to someone that can open it up to clean it.
Nov 26, 2007 | GoVideo VR3845 DVD Recorder/VCR
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
My dvd recorder keeps ruining blank dvd+r's.
I have suffered the same problems as you describe here. What I believe is this unit suffers from inadequate ventilation. After having this problem I examined the unit and noticed it was hot. What I've done is put 2 small flat blocks on each side of the unit, to basically suspend it so that it can get airflow under and over it, now staying much cooler. Nearly all problems now have gone away. Seldomly, I find it will still exibit the problems mentioned. Frankly the only solution I've found from there is to unplug it for a short while and, upon plugging it back in, and trying again it works flawlessly.
Feb 25, 2007 | iLO DVDR05 DVD Recorder
Emerson DVd with Video Cassette Recorder EWR20V5
Try using 8x and lower DVDs and -R ones; try cleaning with CD cleaning disk and then try recording a few min again. If that doesn't help try unplugging and waiting about 30min then put in disk that was previously recorded and go to last item and play it to end (if 2hr long skip to last skip and then play until it finishes) - now try just recording a few min using the manual DVD record button and see if error comes up again - usually this unplugging somehow resets everything. Hope this helps ya'll.
Oct 25, 2006 | Emerson EWR20V4 DVD Recorder/VCR
Philips FW-R7 CD Shelf System Logo
96 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
