You said that it is an older version?Right? and it will only run for windows 97/98. The tendency of having an older version is the compatibility issue within the platform that will use to run by the software. Try to install the software, if it works for vista then there is no compatibility issue with it but if it doesn't work then you must obtain a newer copy of the software that will be compatible to run under windows vista environment.
Please don't forget to rate me..:-) Thanks..
