Hi I have model No WF 740 1400 spin! However programme L is filling up with water, appears to be washing as normal until it reaches final 7 minutes, then machine becomes laboured and will not spin! the programme continues to labour until it reaches No 1 and will not switch off! attempts to cancel the programme are fruitless and the programme reads F 0 5! after 30 minutes the door will open however the machine is full of water and the clothes are soaking wet! please help or advise!
F 05 is a water temperature sensor error. If during the water heating step in the wash cycle, the water temperature sensor (NTC)value is out of range, or the heating element circuit has failed, the F05 error code will be displayed. Check the water temperature Sensor, heating element and element relay. Check the connections to the Sensor, Heating Element and the Relay.
it appears that the pump is not removing the water that is spun out if there is a belt on the pump then it may have fallen off or need replacing if it is intact then the pump either failed or there is a blockage in the line
I have a hotpoint aquarius WF540 machine. It has stopped working and the Wash Enhance &...
(More)
I have a hotpoint aquarius WF540 machine. It has stopped working and the Wash Enhance & Rinse Load lights are flashing. What does this problem mean?
washing machine, will not spin all the rest of the cycle seems fine, clothes still very wet at the...
(More)
washing machine, will not spin all the rest of the cycle seems fine, clothes still very wet at the end of wash
