Lennox heater wont turn on when switched. It is a Lennox 80MGF3/4
  • florikry Jan 06, 2008
    Ed this is florikry, I dont know what unit and what cord you are talking about? Thank You
Sorry, I wished I could be more percise on my answer, but your statement on the problem is too vague. An AC volt meter is necessary to check the unit. First one needs to check the cord to assure there is 110-120 volts AC present. If so, comtinue to check if the fuse is bad. If the fuse is good, it would likely be a heat senative thermal fuse. I hope this somewhat helps.
Ed
NC Electronics
Mills, Wyoming
Posted on Jan 06, 2008
Gas furnace wont light
if pilot light is on, probably should be a knobs with settings for PL only, on, or off.
Nov 09, 2013 | Heating & Cooling
Lennox g26 will not fire up
does the inducer motor turn on? are all the safety switches closing properly? hot surface igniter come on? need more info
Nov 13, 2012 | Goodman GMS90703BXA Heater
Reset limiter switch on Lennox g10 furnace
Try turning the power off to the unit sometimes this works
Mar 05, 2012 | Heating & Cooling
Lennox gas furnace G21Q4/5-100-1 sometimes won't kick on
Hi check out the flame senser is clean also jump ou tthe pressure switch see if it lights when you do this , igntion modul is just a box with some push on wires just get the right one the info is all on the module
Feb 16, 2010 | Heating & Cooling
We have a Lennox furnas. It runs on propane. Sometimes it will not come on. If we turn off the switch by the fuse before the furnas, it will usually come on. This is not 100%. I have installed a new...
The unit is locking out on a safety. Do you have the model number of the heater? How old is it? This may not be a minor problem. You may want to call a Lennox dealer to assist you.
Jan 01, 2010 | Heating & Cooling
Auto burners wont come on my lennox merit series hvac unit.
At whic step does it sto at and theres your problem. step-1 thermostat calls for heat and vent fan turns on.... step--2 the glow plug or hsi lights ... step-3the main gas valve comes on and heats the box...step-4 when the box heats up it closes a temp. switch to start the main fan motor!
Dec 21, 2009 | Honeywell Heating & Cooling
Lennox lf24 garage heater, starts then shuts down.
Here is a link to the manual for your unit heater:
http://tech.lennoxintl.com/C03e7o14l/mk6x6w5J5/503526e.pdf
The 4 flashes is a high limit or roll out switch is open. There are 2 or 3 little brown or black button looking switches with a little button on the top and a wire attached to each side. Press the button on each, you may hear a slight "click". If you do, that is the one that was open. Hope this helps.
Oct 31, 2009 | Heating & Cooling
Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Jan 13, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
142 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
