Question about Sanyo DS27800 27" TV
Can't get a antenna signal
I am having problems, i can't get antenna signal from the antenna or get the tv to work with my disc player either.
  • robenski Jan 06, 2008
    is this set worth the cost of repair just what is the cost of a tuner and the possible cost of replacing it
  • 211 Answers
Sound like a tuner module. Processor may also be locked up, but I have experianced similiar problems on this set and found a bad tuner. Good Luck
NC Electronics
Mills, Wyoming
Posted on Jan 06, 2008
  • Ed Meshechek
    Ed Meshechek Jan 06, 2008
    The tuner module pricing starts at about 40 dollars wholesale up to about 100 dollars. Labor depends on the value of the set to you ( the owner ). Our shop price starts at 70 dollars for a 27" TV but of course, prices vary across the country. My suggestion, unless you can fix it yourself, is that you may want to look for another set if you need the tuner. Have a great day
    NC Electronic
    Mills, Wyoming
Get a better antenna or if possible a outside one--set can only deal with the quality of signal that it gets.
Dec 21, 2012 | Philips Televison & Video
No picture on my combo tv/dvd
no picture means
it can be a damage to vertical or horizontal ICs or any other important IC sir
Jun 27, 2008 | Televison & Video
Hook up and programming
have you try to check the the video cable connections from the dvd to the tv..?
Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
It's staying on 480i sd why not 1080i
There's only one way to get that TV to switch from 480i (which is an SD or Standard Definition signal) - that's to provide it with an ED or HD resolution signal (a 480P signal is often called ED or Enhanced Definition while 720P, 1080i and 1080P signals are called HD or High Definition).
The old standard yellow composite video cable.
You will not get ED or HD signals through the old composite RCA phono jacks (usually yellow in color), either. You'll need to use an RGB (red, green and blue) component video cable, HDMI cable, DVI, or other type supported by both your TV and the video source (CATV box, Blu Ray disc player, Satellite converter, etc.). More on this, later.
RGB cable.
An HDMI cable - this provides Digital audio signals, too.
A DVI cable.
First, you'll need a source capable of sending ED or HD signals. This can be a progressive scan DVD, Blu Ray player, HD Cable or Satellite converter, or a simple TV antenna. Not all DVD players are capable of the 480P progressive scan output - it must be labeled as such. The DVD movies are not labeled progressive scan as they all will play back at 480P if played in a DVD player capable of progressive scan, otherwise they play at 480i. A stand alone Blu Ray player or one in the Sony PlayStation 3, the older HD-DVD in the Xbox360, (it is important to note that the Nintendo Wii can output either 480i or 480P signals only when connected with their special component video cable), "set top boxes provided when you choose HD service from your local cable provider or satellite TV provider are the main sources for signals better than 480i. As mentioned above, the old standard yellow video jack is not capable of supporting signals better than 480i. You must use the HD jacks and cables between to get these signals into your TV.
The Wii 480P cable assembly - includes stereo audio, too.
Lastly, if your TV has an ATSC tuner (it is not uncommon for it to have an NTSC tuner and CATV tuners as well), you can input a UHF antenna directly into the the antenna terminals on the TV. Broadcasters in most areas have been moved into UHF bands - but some areas have one or two that operate in the VHF bands still. Check antenna web for information and help selecting antennas and broadcasters in your area. The nice thing about the antenna method is that no other cables, converter boxes, etc are needed to enjoy HD signals - plus - they're free!
Just remember you need a source capable of ED or HD signals and a way to get those signals to your TV. The yellow composite cable is from days ago and only passes 480i signals.
I hope this helps and good luck! Please take a moment to rate my reply - thanks!
Feb 16, 2011 | Polaroid TLA-04011C 40 in. LCD TV
I have a problem conecting my sharp 25h-M60 with my DVD plyer.I have found solution on Fixya. They said I have to use VCR. My question is: What does VCR mean?
If your TV does not have AV inputs (RCA jacks for video and audio), you can't plug the DVD player directly in to the set. One solution is to connect the DVD player to a video cassette recorder (VCR) using the "line in" jacks on the VCR, then using the channel 3 or 4 output from the VCR to the TV. This solution may not work with discs that have copy protection, though, and will give you an unwatchable picture.
For sets with no AV input, you need an RF converter. This is a device that takes the video and audio signals from a DVD player or other device and makes a channel 3 or 4 TV signal to the TV's antenna connector. Converters are available at most retailers where you can buy televisions, as well as online.
Jan 01, 2011 | Sharp 25H-M60 TV
Why wont my digital tv work now?
External antenna is not adequate. Need more and bigger antennas for digital TVs. Also, several BAD problems with digital TVs - including weaker signal, picky signal, inability to use in a moving vehicle (kids can no longer watch TV while moving from place to place). More expensive receivers, not normally useable in remote places (like you could with analogue).
Rarely, two or 3 antennas on a vehicle will allow for some reception in a slow-moving vehicle - otherwise, portable digital TVs are useless.
Oct 20, 2009 | Jensen VM9510 Car DVD Player
No antenna signal nor found channels for my area.
You'll need a better antenna to solve your problem. With the new digital broadcasting, signal strength is everything. With analog, a weak signal would give you a watchable but fuzzy picture. A weak signal with digital gives you nothing, or possibly a picture that freezes up or breaks into blocks (pixellation). The only cure is a better antenna, either an amplified indoor antenna or something outside.
Sad to say, there's no guarantee that will work. If you live too far from the station, or have hills, buildings or other obstructions that block the signal, you just may not be able to pick up some channels. In some areas people have found they get no reception at all.
At there's a tool that will tell you what stations are around your area and how far. It's designed to help you figure out what kind of antenna you might need.
Jun 15, 2009 | Insignia IS-PDVD10 Portable DVD Player
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Converter box
3/23/09 --- I don't understand why you would hook your converter box or antenna to your DVD Player. Converter box is only functional between an antenna and a vcr (and/or a TV). DVD Player hooks directly to TV (NOT thru a vcr, coding on dvd discs will screww up the signal and make it fade!) Good luck.
Mar 20, 2009 | Insignia Digital-to-Analog Converter for...
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sanyo DS27800 27" TV Logo
83 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
