Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Problem for Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft....
Water leaks from below the fridge
By kierentv on Nov 08, 2009
a couple times a day?
Solution #1
posted on Nov 08, 2009
Not Rated)
Controlfrk
Rank: Guru
Rating: 94%, 90 votes
There are several sources of water from within your refrigerator. The most likely source for the frequency you are experiencing, "couple of times a day", is the defrost system.
When your refrigerator defrosts, a heater that surrounds the evaporator piping behind the freezer back wall comes on which melts the frost on the coils causing the water to run into a drain below the evaporator. This drain can clog up with foreign particles accumulating in the drain. The clogging can cause the drain to spill over into the floor of the freezer and run out the door along the bottom of the freezer door through the door seal. This will usually leave an ice sheet on the floor of the freezer. If you do not have an ice sheet...the drain is not clogged.
The second method by which water ends up on the floor is a broken pan beneath the refrigerator intended to catch the water as it leaves the drain in the freezer. To test this, use a turkey baster and pump water into the freezer drain at the rear bottom of the freezer behind the wall using the holes in the wall. Watch under the refrigerator to see where the water ends up.
Performing these actions will lead you to the solution.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire Gallery Series
Questions and Unsolved Problems for Frigidaire Gallery Series
Do you recommend Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...?
Answer
Answer
Glgfs66csb stove was never kept clean and the spills have baked on. I've tried everything, even... (More)
Answer
I took the bottom shield off the bottom of my dishwasher. It came off in 2 parts - an upper and... (More)
Answer
Our refrig and freeze stopped working today. We vacuumed out the back and it wouldn't work. After... (More)
Answer
I have my indoor ice dispenser set for cube and it only dispenses crushed. How can I get it to reset... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire Gallery Series...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
