Question about Hayden Industries SuperVac 2400 Central System Vacuum
Hayden Vac2400 my hayden 2400 does not have any suction and it smells like something is burning, is it the motor?
  • Anonymous Mar 26, 2014
    no suction
  • 45 Answers
Check the carbon brushes, they maybe worn out and need replacing.
Posted on Jan 06, 2008
I have replaced the circuit board twice on my hayden 2400 and after working for 24 hours the circuit board then fails, with no signs of it tripping. Everything is wired in correctly the supplier is unsure...
Disconnect the wiring from the unit, and go back and plug in your hose.
Get a volt tester and test the voltage coming from the lines at the machine. It should read 0 volts. Check both AC and DC voltage.
Also, check the same setup if you have a security system. Arm the security system (or have someone do it for you) and test the voltage at the line again. Again it should read 0.
If both come up 0 volts, the security and the hose I mean, unplug the hose and try one more time again AC and DC volts.
The only other thing i could see it being is a problem with the motor, if the unit is 7-10 years or more, it may need a set of motor brushes for the motor.
Let me know how this goes.
Mark
Nov 08, 2010 | Hayden Industries SuperVac 2400 Central...
I need a Hayden Superpack Deluxe owners manual so I can change the belt
Hi There,
Actually Hayden uses Panasonic to make all of their power nozzles. Replacing the belt on your Hayden is the identical process to replacing the belt on Panasonic canisters. Kenmore canisters also use Panasonic power nozzles, it's the same process with these.
There is also a power nozzle overload switch on the top of the power nozzle that will shut down if anything is vacuumed up that causes stress on the belt. Try pushing this reset switch before opening up the power nozzle to install a belt. It may be something as simple as a reset switch.
If this doesn't work, here's a link to a repair that I've posted on Fixya on how to replace the belt on a Kenmore canister power nozzle, the process will be identical to your Hayden power nozzle.
http://www.fixya.com/support/t4563318-change_belt_sears_vacuum
Hopefully this helped you. Please be so kind and rate the repair, or leave feedback for the fixya community.
Thank you,
Chris
May 22, 2010 | Hayden Industries SuperVac 6000 Central...
Hayden product. how to disassemble the head to replace the belt.
Actually Hayden's power nozzle is manufacturered by Panasonic for Hayden. Panasonic is the same maker of Kenmore vacuums as well. I have written a detailed repair solution on how to replace the belt on a Kenmore Canister vacuum, and the repair on your power nozzle will be identical.
Here's the link:
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
The only difference could be that you may have a newer style power nozzle then this one, and the screws on the newer nozzles are actually on the bottom of the power nozzle rather then underneath of the headlights.
Hope this helped you,
Chris J.
GoVacuum
Apr 10, 2010 | Hayden Industries SuperVac 3600 Central...
Where can I find a part for my BV2000 in house vac? It is the smallest unit made by M S & S Systems in Dallas TX. The suction impeller is grinding in it's housing, so I need a motor/suction pump. I...
you will have to replace the whole motor as these motors where never made to be serviceable. if you take the motor to a local vacuum shop than can order you a new one. though i would recomend replacing the whole tank unit with a Nutone or Hayden they are far better systems.
Jul 25, 2009 | M&S Systems BV-2000 Bagged Canister Vacuum
Odd noise coming from central vacumn cleaner
The rattling noise, will likely increase when the head is flipped upside down. Generally means you have a stone caught in the belt or a blown or stripped tooth on the belt.
If you gently squeeze the outside edges of the light housing it will pop off to reveal two screws to remove the lid. Check for other screws at the neck of the power head. Once removed your belt and brush will be visible. Remove the brush roll with end caps and flip the belt inside out rolling it between your finger , look for cracks or a floppy or missing tooth. Replace if any sign of wear.
Inspect the dust caps on your brush. There is a washer under each, likely buried in lint. Do not lose as these are a spacers for each end of the brush. Clean shaft and lube with WD40. Spray caps with the same. vacuum loose grit and dust bunnies away from motor and reinstall, your red button must align with the lid when replacing
Jul 19, 2009 | Hayden Industries SuperVac 2400 Central...
Hayden 6000+ wont run
Define hose works or doesn't, no suction, hose will not activate vac , etc.
Test the vac by shorting across the low voltage terminals where they enter the machine. If the vac works here your problem is in the internal wiring, at the valve or the hose to wall connection. If the vac will not run, you will need to check the motor for continuity across the motor leads.
Apr 18, 2009 | Hayden Industries SuperVac 6000 Central...
Hayden Super Vac Premier will not stop unless I unplug
one of two problems cause this. first is a short in the wires that turn it on, the small wires going to the side of the body unplug one of them to see if thats the problem
second is a stuck relay inside the top cofer of the main body
Jan 26, 2009 | Hayden Industries SuperVac 6000 Central...
Hayden Supervac 3600
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11860&thid=808510
Posted by kdm0 on Jul 20, 2008
Hi, I have a Hayden Supervac 3600 central vac system in a house I just purchased. The Amber light indicating that it needs regular maintenance is on. I have cleaned and serviced the motor, everything is fine and suction is well. How do I reset the service light? The reset button seems to do nothing. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I heard of this happening before and you need to refer to the owner’s manual and or to contact the factory or manufacturer of which I will provide to you @ the end of this question. There may be some type of rely switch or board that might need replacing but check with the factory. If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.haydenvac.com/company/company.html
Customer Service 1-800-461-5300
Company Phone # 1-705-726-3361
Company Fax 3 1-705-726-2186
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 20, 2008 | Hayden Industries SuperVac 3600 Central...
Spare part - filter
You will have to find a Hayden store that sells and installs Hayden systems.
Mar 15, 2008 | Hayden Industries SuperVac 6000 Central...
Hayden Industries SuperVac 2400 Central System Vacuum Logo
222 people viewed this question
Top Hayden Industries Vacuums Experts
Are you a Hayden Industries Vacuum Expert? Answer questions, earn points and help others
