Acer has no power
I have had my computer for about 6 months it has had 2 power supplies put in it and still wont start sometimes.
  • scott0007 Jan 06, 2008
    thanks for your advice j you have been very helpfull. cheers.
  • 417 Answers
If it only 6 month sold send it back to the store you brought it from as you should have a 1 year warranty with it. The other thing is when you switch the computer on does the power light come on and nothing happens? If so then the CPU could be out of it's socket slightly which this will have nothing to do with the power supply.
I suggest if you have had it from new send it back to the store if you purchased second hand open the cover detach the CPU fan and lift the release lever and push down on the CPU and close the release lever then replace the CPU fan and cover then try switching on.
Hope this helps you
Cheers J
Posted on Jan 06, 2008
Flashing green light and monitor wont start
There are one or two capacitors that open in the power supply, sometimes it will have a bulge at the top, making it easy to spot.
Apr 05, 2012 | Acer Computers & Internet
Acer 5610 charging difficulty
Yes! the DC jack will probably need to be resolded, and I would recommend replacing the power adapter because it may fix your problem, I find the universal supplies don't fit as tight as the original ones. www.ebay.com is a good place to start for power supply replacement.
Mar 30, 2012 | Acer Aspire 5600 Series 5610-2013 Notebook
Just brought new memory for my acer aspire sa90 desktop,now my computer doesn't seem to turn on
i assume computer was starting correctly before? this is older computer and it is using sdram memory, locket on them sometime do not clip in correctly.
1. switch off computer
2. remove power cord
3. remove side wall
4. remove sdram
5. check sdram orientation and type, if they correctly align with registering notches
6. release lockets to max, (outward from slot)
7. re-insert correctly oriented sdram till lockets close into sdram stick (you may give them bit "help" to close in position)
8. re-connect power
9. start computer
if copmuter start normally, that meant tha tyou fixed the problem, if not, switch computer off and remove power cable, check motherboard power cable insertion, and repower again.
if computer start, lose cable was the problem.
if computer still do not start, remove new memory and re-nstall old one, if computer start, new memory will be a culprit.
if computer no fan "jig" and no light blink, remove all power supply cables from motherboard and connect in it's place new power supply, to exclude power supply problem.
if computer start with new power supply, old power supply will be the problem,
if computer do not start, and no joy with checking, but fan is running, including on the processor, this will indicate either, motherboard or processor died... if that is the case further testing will be required to determine which is exact cause. as in home situation there are usually no motherboard testing equipment, you need to go to more difficult path of changing the processor, checking video and haveing second computer on which you can test all of that...
replacement board for that processor on ebay cost from about $0.99 plus postage. if you need any further advice, please re-post adn if i am on line today, i will provide you with further procedure how to test your video, motherboard and processor.
if you find my advice useful, please do not hesitate to leave your comment and vote 4 for me, thanx!
Aug 01, 2010 | Acer Computers & Internet
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Power but no display acer aspire L100
Try these sequence(you need another one good computer to test and interchange component and you will find out the problem):
- check your RAM, if you use two RAM start computer using one and interchange it to find out which one is bad
- if your RAM OK, check your VGA
- if your RAM and VGA OK, try to check your power supply, sometimes defective PS cannot supply sufficient power to all component to work.
hope this will help you.
Jun 07, 2009 | Acer Aspire L100 PC Desktop
Power supply replacement?
try www.tigerdirect.com they carry tons of pc parts including power supplys i built my whole pc from their website and they have 24 7 live telephone support and if they aint got it they can get it im not trying to promote them but they aint never done me wrong
May 21, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
My laptop will not power up
try this. Turn it off. take out the battery and press the on button for 2 minutes before you release it. sometimes this will reset a computer and then it will start up. Then you can put the battery back in
Apr 19, 2009 | Acer Aspire 5315 Notebook
Computer wont turn on or boot
what size power supply are you using, if its under 400 watts it may just be under powered. Large video cards 512mb and over take a lot of power. Try removing the video card and see if you can get the pc to power up, hopefully you have on board video.
How did you blow the cpu_fan connector, did you short it out? I would first supect the power supply is under rated, second a blown power supply, or mother board.
Mar 14, 2009 | Computers & Internet
Acer laptop travemate wont even make any noise or boot up... why?
My initial thought would be that your battery will no longer hold a charge or that your power supply has gone bad. Try taking the battery out and booting the computer with JUST the charger. Any change? How about booting from the battery alone? Have you had any spills on or near it in the last 6 months? If it turns out to be a battery, you can buy them online for around $70. There seems to be an abundance of parts for this model acer. It definitely sounds power related though. If its not the battery or the power supply, my last guess would be the motherboard. Good luck and let me know if things change as your are testing it.
Feb 21, 2009 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
96 people viewed this question
Alun Cox
David Payne
David Payne
