I keep getting the error that C:windowssystem32configsystem is corrupt or missing, and it says I can repair it by inserting the CD and pressing R.
So I popped in the CD, booted from the CD, and it all seemed to be going well, but when it gets to the point where I have to press either "enter" "r" or "f3" I press R to repair, and nothing happens, pressing enter also does nothing, as does pressing f3. The only thing I can do from the screen is turn off my computer again.
Now the reinstall CD I'm using isn't from my Dell Dimension 9150 it's from a older Dell computer that was purchased two years before. Could this have something to do with my problem?
When Windows is installed on a computer, it assigns a hash value for the major hardware components inside the computer.
You may think of it as assigning serial numbers, for each major hardware component. In reality it isn't a serial number, though. Just a specific value attached to THAT hardware component.
Some of the major hardware components such as;
1.Processor 2.Harddrive 3.Motherboard, (Actually the BIOS program and version, which is burned into the BIOS chip, on the motherboard) 4.Graphics chip (GPU)
Now THAT genuine copy of Windows is matched to THE computer it was installed on.
(It is a security feature that Microsoft implemented long ago. A feature to try to insure that their software would not be stolen. Microsoft Users License states "One genuine copy of Windows per One computer"
Helps to keep thieves from taking One Genuine copy of Windows, and installing it on 1000's of computers.
{Microsoft makes one Master disk of an Operating System. Such as Windows 95, or 98, or 2000, or Me, or XP, or Vista. Then they copy off the genuine version that you, or I receive)
The Restoration disk has the needed Windows files. File for Windows System32.
Files you need right now. Except the ones on the restoration disk you're trying to use, is for another computer. The Restoration disk also has needed Drivers, and also has the files needed for the Programs, and Applications. Trouble is, they are for the other computer, and not the one you have now.
when i try to format my computer it is ok but i try to install a software it doesn't continue but if...
(More)
when i try to format my computer it is ok but i try to install a software it doesn't continue but if i try to the other computer the software will continue installing maybe what it is cause
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP...
(More)
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP scanning software, but I have not been able to install the scanner so that it works with the Vistascan software. I much prefer Vistascan as it is much more user friendly & offers more flexibility. Any help would be appreciated.
how do i make adjustments to the dclcd s1702d monitor. the screen is completely light green. i get...
(More)
HOW DO I MAKE ADJUSTMENTS TO THE DCLCD S1702D MONITOR. THE SCREEN IS COMPLETELY LIGHT GREEN. I GET NO RESPONSE TO ANY OF THE BUTTONS LOCATED AT THE BOTTOM FRONT OF THE MONITOR. THANK YOU
