When i reformat a maxtor 40gb with ASUS MotherBoard it will pause formatting in just 54 percent .. Then i try uing quick format then it will run and continue. then again it will start XP then it says primary drive fails then i pres F1 to continue then it will start Inspecting hardware Configuration it start again and again...i try to format the HDD to another Mboard its succesfully load the xp os...then i again i back the HDD to ASUS board primary drive fails// what sould i do...??
Try to format your hard drive using Maxtor CD not windows XP. You may have a bad drive, see if you can write zeros to the drive it can fix a lots of problems.
buenas noches, temgo una board msi_k9mm_v_ le acabo de cambiar el hd tenia uno de 250 gg y se lo...
(More)
BUENAS NOCHES, TEMGO UNA BOARD msi_k9mm_v_ LE ACABO DE CAMBIAR EL HD tenia uno de 250 Gg y se lo cambie por uno de 320, tambien la desarme totalmente y la limpie, ahora que la volvi a armar, la CPU prende, las unidades de CD abren y cierran, pero el monitor se queda en negro, no da ninguna señal y cuando la reseteo no apaga, he revisado mucho las conexiones que esten bien y no encuentro el rpoblema, me pueden colaborar por favor? gracias LILIANA
have e computer,twise change the mother board,also diferent power suply.......the computer is...
(More)
have e computer,twise change the mother board,also diferent power suply.......the computer is workin,the fan is moving,so,is currente of elecriciti good.but the monitor,first son like is workin,then fui secondos nothing.....don't now because is no signal......?memoty is good,mayve diferent video card..........thanks....alonso.....
hi i have loaded football manager 2009 onto my computer, but it won't let me play it, it comes up...
(More)
hi i have loaded football manager 2009 onto my computer, but it won't let me play it, it comes up with a fault saying cannot set-up graphic system, any ideas of how to get round the problem????
asus p5s800-vm-uaygz نزلت...
(More)
asus p5s800-vm-uaygz نزلت ويندوز جديد ومعنديش اسطوانة تعريفات الماذر بورد عايز التعريفات الخاصة بالمذربورد
