Question about Hotpoint Aquarius WF210 Front Load Washer
Hotpoint wf210 No light at all
I have just changed the pump as it was jammed with an elastic band and would not drain. On replacing it I now do not get any ''On'' light or life from the washing machine. The Socket and plug fuse are fine so I have no idea why I have no power. Can you suggest anything?
  • 108 Answers
I cannot tell you how to fix, jut trouble shoot.
Turn off power and unplug.
Do a visual inspection of all electrical connections you were working close to.
Re-check every electrical connection you had to disconnect and reconnect - remove and reseat.
Regards
Posted on Feb 25, 2008
6ya staff
SOURCE:
Samsung wf 210 front load washer nd code
Check out the drain hose and connection hose to pump and then check out the pump in the washer for any clog or junk stock in the pump and clean it with warm water and test it is working properly or replace if it is not and reinstall the pump
May 21, 2014 | Hotpoint Aquarius WF210 Front Load Washer
Hi, Have a hotpoint WF440, it will only do a short spin, then the lights flash on and off... the water is being drained, but clothes still soaking wet... any advice please.. Des
if your washer drain hose is connected to your sink waste it may be blocked there allso you should check the pump filter may be blocked these 2 things are very common faults as what you have discribed
Sep 25, 2011 | Hotpoint Aquarius WF210 Front Load Washer
If we have a new Samsung WF210 washer. the drain that we have to reach is approximately 7'-6" high (from floor). We have attached drain extension to the washer and have run it into the drain. Will...
Hi it will have a impact on your washer in time because the pump will block up causing you problems the recommended hight is 2ft 6 ins short term it will be ok
Aug 03, 2011 | Hotpoint Aquarius WF210 Front Load Washer
I'm trying to find instructions to remove and then fit new door seal on hotpoint WF210, have lloked at tsome online videos but the wf210 doesnt seem to have the outer retaining ring releases as shown on...
I find it easy to remove front casing to fit new door boot seal First remove soap drawer then the 4 screws here next pull off control know of timer next 3 screws on front panel this then now drops down with wiring attached the front of the machine has 3 top and bottom screws remove them along with the door interlock switch 2 screws......detach the band or wire around the door seal the front panel can now be removed.....Seal is in front of you secured by large metal band and screw undo this fit on new seal refit ring and bobs your uncle as they say Good luck....
Apr 21, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint WMA74 does not pump out after programmed
No test available other than:
Remove pump - check motor will turn by rotating impellor. There is a slight resistance then moves freely, then slight resistance and freely again. This is correct for this machine. worth checking there is no hair, elastic band or other obstruction around the impellor fins and shaft whilst the pump is out.
There is no spin cycle so you have to use rinse & spin, which means if the pump is shot you need to empty the machine each time :(
Worth checking lower filter as stated and blowing down the drain hose whilst the pump is off to check for obstructions.
The resolution to my problem was a new pump - £20.
All working fine again now !
Jan 24, 2010 | Hotpoint WMA74 Front Load Washer
Water flooding from drawer would anyone be able to kindly help
ck the pump for lint ect . and clean it out a slow drain problem could cause this . also a kink in drain hose .. hope this is helpful . mm
Dec 02, 2009 | Hotpoint Aquarius WF210 Front Load Washer
The water wont drain or spin wf210 hotpoint
Hi I think your problem is that the filter is blocked, filter is located between drum and pump at the rear, clean that out and that should solve the problem.
Mar 08, 2009 | Hotpoint Aquarius WF210 Front Load Washer
My washe keeps reading either F04 or F05
F04 - Pressure switch jammed on empty while F05 is a blocked filter.
Check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an engineer.
This really is your only option.
Plz rate my solution
Thanks.
Jan 19, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
