Sterling Plumbing STERLING PLUMBING 1500D-36S "VISTA PIVOT" SHOWER DOOR
Problem for Sterling Plumbing STERLING PLUMBING 1500D-36S "VISTA...
My shower (fiberglass) drain is leaking and needs
By fleabait on Nov 08, 2009
My shower (fiberglass) drain is leaking and needs to be replaced. I can pop off the drain cover to reveal a pvc collar that is glued down and unmoveable. I have ripped the ceiling open underneath the shower and can see light coming through brightly in the upstairs drain. I don't know how to remove the old pvc drain. Any suggestions? Thanks, Susan
Clarification Request
Posted by hohox5 on Nov 12, 2009
where is the leak is it the drain collar or pipe coming down or shower pan(floor) pvc is glued into place u have to cut it out-- but before u do it may be possible to repair leak
Solution #1
posted on Nov 19, 2009
Not Rated)
36069
Rank: Master
Rating: 85%, 4 votes
There are a few different drain styles available. If you pop the drain cover off of the shower, does it look like a brass ring pressed up against a rubber boot? If this is the case, that brass ring will have to unscrew first. if this is not the case, There will be a large nut on the underside of your shower that holds the drain in place. Often times, a helper is very beneficial to hold the top part of the drain assembly in place while the other person unscrews the bottom portion. You may say a few choice words during the process, as sometimes an older drain becomes hard to unscrew. There is a special tool for removing the drain, and it is relatively inexpensive. If the pvc is glued into the drain, a section of pipe will have to be cut away to get the tool around the strainer nut. Plan on replacing the trap and strainer. If it is pvc, you will need a coupling, trap, plumbers putty to go around the strainer where it meets the base of the shower, a new strainer, and possibly a couple street 45's and a couple of 45's. Don't forget the glue, primer, and a short piece of pipe.
Was this helpful?
Yes
No
Popular Solutions for Sterling Plumbing STERLING
Questions and Unsolved Problems for Sterling Plumbing STERLING
Do you recommend Sterling Plumbing STERLING PLUMBING 1500D-36S "VISTA PIVOT" SHOWER DOOR?
Answer
Answer
i have a triton power shower, when i switch it off, water still comes out ,what is the problem
Answer
the setup has a red circular plastic ring that is threaded on the handle stem. It seems locked into... (More)
Answer
cannot ajust tempreture control after fitting new pump
Answer
i have just installed a quarter turn Quattre Mixer Shower from B&Q and cannot get the water... (More)
Answer
I have a sliding shower door in my bath but unfortunately, I do not know the manufacturer of it.... (More)
Describe your Shower Hardware problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Shower Hardware Experts
Top Plumbers
in Newport, KY
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(866) 897-9936
316 2837038
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
