Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Display fried hi, my display is fried...just a big dark tear drop...the buttons still work, is there a book that shows the screens so I can manuveur? Thanks Bo
  • Anonymous Jan 27, 2008
    Hi, I have the same problem. I contacted the technical support and was told to reset and press the play and on button at the same time after which to do a clean up. After trying that it worked for the day but now I am back with the same problem :(
    Gonna contact them again soon. Will keep you posted if I find a solution. BTw, mine is Creative Zen.
    Problem Solver:
  • 7 Answers
If it's a dark teardrop, then the LCD is broken. If it's just blank, then you may need to reseat your screen, which will require you to completely disassemble your unit and will void your warranty.
Posted on Mar 08, 2008
My compac presario CQ57, got diet coke on it thanks to my 2 yr old. Nothing comes up on the screen. However it does power up and I can hear sound. Any fix for this?
Maybe you got lucky and only the lcd inverter got fried. Try the steps below.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 30, 2012 | Compaq Computers & Internet
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
Toshiba m60-104 screen dark new screen new iverter
Have you tried an external monitor?
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the display shows on the external monitor that proves your video card is ok and your lcd screen is the issue. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If is shows on the external monitor, then you would have to question if the new screen and lcd inverter is bad. Just because they are new don't mean they work. Are you sure you purchased the lcd screen and inverter that is for your model?
May 23, 2012 | Toshiba Satellite M60 Notebook
My daughter was on youtube and now the screen size is way too big. how do i get the screen back to normal. i don't know how to adjust the resolution.
If it is a resolution issue you should go to START --> Settings or Control Pannel --> Display
If you look through the tabs in this window you will find where to adjust the resolution of the screen.
If this does not adequately fix the issue you can try holding the CTRL button on the keyboard and slowly scroll the mouse wheel in and out to adjust the zoom inside the Internet Explorer window.
Jun 18, 2011 | Computers & Internet
Same problem pool heater shows hayward pool heater bo error
BO means that you have bypassed operations. ie automation. if no automation is present then press and hold the Down arrow and Mode button for 3 seconds.
Aug 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Alarm set for certain days
Depress Alarm1 and hold while you then press the alarm mode button until it shows Mon throught Fri. You will then have both Alamrs set for the weekdays but you can set them to different times.
Nov 23, 2007 | Emerson Smartset Clock Radio
Dropped camera-two corners dark
Check what the actual pictures look like when they are downloaded to PC or to print. The problem may only be on the screen. It may be very expensive to replace the screen, but you might be able to live with it?
Good Luck
Oct 25, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
48 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
