Home | Maytag | PAV2300 Top Load Washer | Clanking bearing typ...
Maytag PAV2300 Top Load Washer
Problem for Maytag PAV2300 Top Load Washer
Clanking bearing type sound, agitator moving, tub
By ramagui1 on Nov 08, 2009
clanking bearing type sound, agitator moving, tub draining, after time motor heats and shuts down
Solution #1
posted on Nov 08, 2009
Not Rated)
nanbuenbrazo
Rank: Wiz  Washers & Dryers  Expert
Rating: 78%, 155 votes
you better open the back of the your machine and see to it where the noise is coming from, if you are sure that it is coming from the bearing or bushing of the motor, STOP using your machine, because if you force it, you might damaged the electrical part of the motor and it may burn out.
Just take out the motor by cutting the wires atleast 6 inches away from the motor, remove/loosen the bolt around the motor, slide the belt out then take out the motor, bring it to a machine shop and have it replace there.
Taking it backl is easy as how you take it off (reverse)
Was this helpful?
Yes
No
Popular Solutions for Maytag PAV2300 Top Load Washer
Questions and Unsolved Problems for Maytag PAV2300 Top Load Washer
Do you recommend Maytag PAV2300 Top Load Washer?
Answer
Answer
I Have a Maytag performa Pav2300AWW Model that has quit. It made a squaeling noise like it was... (More)
Answer
My Maytag 512, which is about 15 years old leaks some water to the floor if we leave clothes to... (More)
Answer
Washing machine is rubbing on spin cycle. Tub seems to be angled downward from front to back.
Answer
When the machine begins the spin cycle to let the water out it makes a horrible, rattling like... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag PAV2300 Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14705
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
