Ryobi 15" Electric Factory Reconditioned Trimmer  - Factory Reconditioned
Problem for Ryobi 15" Electric Factory Reconditioned Trimmer...
Need a fuel line diagram for a ryobi scorpian
By micksbitz on Nov 08, 2009
need a fuel line diagram for a ryobi scorpian wipper snipper
Best Solution
posted on Nov 12, 2009
Very Helpful)
mrfixit-jerr
Rank: Guru  Garden Tools  Expert
Rating: 94%, 7979 votes
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly.hope this helps,MrFixIt, oh could you please rate this solution,thank you.. this is for most fuel line trimmers~~~
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Ryobi 15" Electric Factory
Questions and Unsolved Problems for Ryobi 15" Electric Factory
Do you recommend Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned?
Answer
Answer
when should I use the pro cut II head as opposed to the regular head
Answer
I have a ryobi RLT30CES for about 12-14 months and over the weekend the head just fell off and does... (More)
Answer
You mentioned this in your answer here:... (More)
Answer
no fuel entering the bulb. not sure if the lines r backwards or cloged
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Lawn Trimmers and... Experts
Top Garden & Power Tool Repairmen
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
