-   The whole stack of paper began feeding in when I was printing. I pulled it back out and since then it only gives me "Error 5700." I unplugged, replugged, rebooted. Nothing has changed.
-   jan1956
Mar 25, 2008
-   error 5700-   Guest
Feb 24, 2008
-   i''m having a similar problem. mines straight out of the box.. removed the standard packaging tape. plugged it into the power supply & turned it on via the on/off switch.. printer power ups, and then makes a god aweful grinding noise.. lcd screen displays Error code 6000 & the Alarm light flashes.. Tried turning it on & off about 20 times.. looked inside & out and there doesn't appear to be anything jammed in a roller etc.... Any ideas??-   traart88
Jan 17, 2008
-   service error 5700 printer makes awful noise when first turned on as if paper feed trying to operate-   blackhawk60
i have a Canon Pixma iP6000D and I had similar problems right out of the box also. When I investigated, i found a slotted plastic piece with a spring under it that the bottom tray slides into had been pushed out and up into the paper feed mechanism. I just pulled it back down into place and all was well.
Comments:
Mar 20, 2008
- I should have added, I think its terrible engineering and unacceptable. I won't buy Canon printers again either. I hope this helps someone.
Hola tengo un proble con la Impresora Canon, se me atasco la hoja en la bandeja de atras y luego lo jale duro, ahora me sale un "error" es el " 5700" y no puedo hacer nada, alguien me puede ayudar alguien tiene el kit de mantenimiento, que me lo pueda mandar, max_el_diablillo@hotmail.com
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MX700 All-In-One
After trying to run perferated card stock the printer never loaded if form the back and then...
(More)
After trying to run perferated card stock the printer never loaded if form the back and then produced an effor code 5700. I have cold booted unplugged and it remains locked out with the alarm light on
I get an error code 5100. Printer does not start to print. I have checked the printer head and...
(More)
I get an error code 5100. Printer does not start to print. I have checked the printer head and cleaned it. Only on print catridge is low and flashing.
