Heaters
Problem for Heaters
Generic problem for all Heaters
I have a hydrotherm boiler with a mil...
By qualitycomfo on Nov 08, 2009
i have a hydrotherm boiler with a millivolt gas valve and when i go to hook my thermostat wires up the pilot drops way down and my millivolt reading drops to 16mv why is that
Clarification Request
Posted by bryan614 on Nov 10, 2009
are you saying the actual pilot flame drops in size? or are you saying that the millivolt output drops to 16miilvolts with the main burner on?
Solution #1
posted on Nov 11, 2009
Not Rated)
adamsaire
Rank: Guru
Rating: 94%, 21 votes
Make sure your thermostat can be used with a millivolt system.Most thermostats are for 24 volt systems and don't work for millivolt systems. Also your thermostat wiring cannot be too long and it also needs to be the correct gauge. Normally the thermostat wire size should be 18 AWG up to 50 feet in distance. Also all your wiring connection have to be clean and tight(solid connections). If your connections are the slightest bit loose your millivolts will drop.
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
best heater for a 5,000 square foot monolithic dome
Answer
how can you buy things for less than what they ask for?
Answer
the furnace model# DGAA070BDTB will ignite then almost immediately go out it will the ignite again... (More)
Answer
If we pick it up while it is running inorder to direct heat in another direction, it often shuts... (More)
Answer
heater remington 35 wont fire tried then tripped out . Now wont fire just blows air ?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heaters Experts
Top Heater Repairmen
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
