Question about MiniDisc Players
Accurian AMA 2336
Can't get the i-pod dock (Accurian 2336) to come up on my computers...any three. It it there momentarily then disappears. The apple i-pod works perfectly with the Apple USB wire to the computer.
  • 107 Answers
SOURCE: Accurian 2336 i-pod dock
try to go to this site though and download this.
this is an Itune start installer. hope it will help you.
Posted on Feb 14, 2008
0 characters
1 Points
Cd tray stuck will not open
Apple does not make minidisc players.
Aug 28, 2012 | Apple MiniDisc Players
When I put 3 cds in the tray and close it, it goes through all three dics and shows no disc. WHY?
possible solutions:
-insert disc with labelside up
-clean cd/dvd blanc surface with a soft fabric
-use cleaning cd to clean lens
-change pick-up laser or eliminate electronical defect (service issue)
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Mar 27, 2011 | Sony MiniDisc Players
How can i select auto pause on my player model je510 thanks
Inserting blank spaces while recording to tape (Auto Space)
The Auto Space Function inserts a 3-second blank space between each track while recording from MDs to tapes, allowing you to use the AMS function during later playback.
Press A.SPACE repeatedly until “A.SPACE” appears in
the display.
To cancel Auto Space
Press A.SPACE repeatedly until “A.SPACE” disappears.
If the Auto Space Function is on while recording a selection containing multiple track numbers, (for example, a medley or symphony), blank spaces will be inserted within the selection whenever the track number changes.
See Page 21 of your User Manual
May 23, 2010 | Sony MDS-JE480 Mini Disc Player
The part that the ipod fits into has broken how do
After speaking with a Hitachi consultant friend they said the individual dock is not sold seperately from the whole unit currently, at one point it was available but not now. She suggested a few things to try. 1. Look at online parts stores for electronics.. it may be a long time GOOGLING but she said some older suppliers may still have stock. She said the part number on the dock itself is what you need to look for not the actual AXM system number. 2. You can get a 3.5mm headset jack to RCA output cables (the red and white male ends) that would be able to plug into the input of the unit and you would plug the headset jack in the Ipod like headphones. 3. Look on ebay or other sales sites for used systems like yours that are not working or broken. You can get the extra part from them and discard the non functioning part.. or contact the seller to see about only being sent the ipod dock.
Mar 02, 2010 | MiniDisc Players
I have a minidisc model mds e10
it seems your MD unit is expecting a digital signal on the digital input causing this message to appear.
You need to connect a signal source to the digital input
connect an analog signal to an analog input and select the analog input as signal source.
In both cases the DIN UNLOCK message will then disappear.
May 14, 2009 | Sony MDS-E10 Mini Disc Player
Zen mp3 player not working.
I located a reset on the mp3 player and used it by inserting a paper clip in the little tiny reset hole. Fixed the problem, but trying to locate the reset hole is no small feat, a magnifying glass would probably be useful.
Dec 15, 2008 | MiniDisc Players
Mini Disc Not Working
Pull the power cord. Make sure the three-position switch with "REC/Standby/PLAY" is in the middle position, then plug the cord back in. Wait a minute, then press POWER. Now load a disk and wait 1 minute for it to read the Table of Contents (TOC). Either it will show the tracks, or it will say 'empty disk'. Let us know what happens from there, okay?
Oct 06, 2008 | Sony MDS-JE480 Mini Disc Player
Philips Wireless Music Center wacs7000
Well I think thats the probem about this pc's they can't copy a cd file to the pc if its an original, but if copying the files to a new cd it will. maybe it has a copyright. for the pc. well I tried nero to change the file, cuz' sometimes the file is a different format.
or you may use Itunes from apple to download them into your HD. then try to reformat them using nero. ( if nero will)
pls. dont rate me badly. );
Feb 13, 2008 | MiniDisc Players
Jan 05, 2008 | MiniDisc Players
Sansa problem
just go to "My Computer" on your desktop or start menu and go to the removable drive which would be your mp3 player.
The hardware might be incorrectly linked to the computer, the usb cable could be messed up or the computer could just not read it without a cd to install the driver correctly.
Dec 26, 2007 | MiniDisc Players
MiniDisc Players Logo
173 people viewed this question
Top MiniDisc Players Experts
Ben Armstrong
xxxxxx xxx
Are you a MiniDisc Player Expert? Answer questions, earn points and help others
