I believe you have a faulty door safety interlock switch. Please remove the cover and check the small micro switches with your ohm meter.
What frequently happens is this: because of opening the door during oven operation, the small points inside the switches arc and burn. Once they cannot make contact, they are not able to tell the oven the door is closed and when the door is not closed (forget what YOU think the door is doing) the oven will not turn on the magnatron. No magnatron, no heat.
ge jvm1630bb has stopped working. earlier only the digits on teh screen were gone but it would work...
(More)
GE JVM1630bb has stopped working. Earlier only the digits on teh screen were gone but it would work and it would not stop only at times per timer.. but now I see only 1 small 0 digit all the time and none of the buttons work. Any suggestion as to how can I fix it myself and if not, whom to call. I am located in houston, tx. Thanks.
Surface lights and vent fan do not work. When either button is pressed the display indicates...
(More)
Surface lights and vent fan do not work. When either button is pressed the display indicates "surface light" or "fan hi" "fan low", etc
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
