Try to open the back of your washing machine and you'll see the motors, capacitor and belt, don't remove it yet, turn on your unit and look and listen carefully on which part of it is making a noise, if you confirmed that it is coming from the motor shafting (it is the middle of the motor holding the pulley) then it is probably the bearing or bushing(it depends on what type of motor you have)
You can remove it by just loosing up the bolts aroun the motor and take out the belt, about the wires, just cut it and connect it when ready to use.
let the machine shop replace the mechanical part (bearing or bushing)
error 136 keeps coming up.another site suggested checking ohms on the 5 way connector in the control...
(More)
ERROR 136 KEEPS COMING UP.ANOTHER SITE SUGGESTED CHECKING OHMS ON THE 5 WAY CONNECTOR IN THE CONTROL PANEL AND THAT IT SHOULD READ 32 OHMS.THIS DOSNT READ 32 BUT I GET A FULL SCALE DEFLECTION,CLOSED CIRCUIT ?
my intuitive washer knocks/bangs on spin then out of balance bell rings i think the top of the blow...
(More)
my intuitive washer knocks/bangs on spin then out of balance bell rings i think the top of the blow should have 3 legs and 3 springs i only have 1 spring and leg it connects 2. i think it has broken off 2 legs and 2 spring that puts it out of balance on spin can you buy the top of the tube blow and springs
Have a Fisher and Paykel top loading machine. Keep getting a code 37. It won't drain or spin. We...
(More)
Have a Fisher and Paykel top loading machine. Keep getting a code 37. It won't drain or spin. We already checked the hoses and they seem to be clear. I can't find our manual. What else can we do?
