You may have a defective park brake switch or the pto clutch could need to be adjusted.Does the machine **** down when you try to engage the pto?If so also check the seat switch.To adjust the pto clutch you need a 9/16' wrench and tur all three lock nuts on the clutch a half turn at a time a retry the clutch,keep going until it will stay engaged.
I want a tractor that bags, is fast (had a GT 3000 and loved it), especially in reverse, and I can...
(More)
I want a tractor that bags, is fast (had a GT 3000 and loved it), especially in reverse, and I can raise my mower deck significantly to mow my grass high.
I own a John Deere 2010 with disc style brakes. Having a problem getting the outer cover off. The...
(More)
I own a John Deere 2010 with disc style brakes. Having a problem getting the outer cover off. The actuator rod that protrudes through it won't allow me to remove it. Thanks for your help! Joe jgu@buffalo.edu
