check your overflow float inside the machine. it looks like a small hat or cone. it should move freely up and down. if it is stuck down, the water will continue to flow in. the gasket is designed to stop splashing water. it is not an underwater seal. good luck
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 15689 Built-in
I need to unlock the unit. The lock light is on and I can not unlock it. It is a Kenmore Ultra...
(More)
I need to unlock the unit. The lock light is on and I can not unlock it. It is a Kenmore Ultra Wash 4 Dishwasher
Our dishwasher (Kenmore Ultra Wash Quiet Guard 3) stopped mid-cycle... it blew a fuse. I flipped the...
(More)
Our dishwasher (Kenmore Ultra Wash Quiet Guard 3) stopped mid-cycle... it blew a fuse. I flipped the breaker, but now I cannot get it to turn on at all. Is there a combination of buttons I am supposed to hold down to 'reset' it?
Comes on won't fill. if you shut it off. 2 minutes Appears (drain) light on and drain pump will...
(More)
Comes on won't fill. if you shut it off. 2 minutes Appears (drain) light on and drain pump will Drain washer (if you add water to Bottom of Dishwasher)
Dishwasher stopped running. Won't restart. It seems to have run through a cycle. Water sitting in...
(More)
Dishwasher stopped running. Won't restart. It seems to have run through a cycle. Water sitting in the bottom. No lights. Buttons not working
