The shredder runs like a charm in reverse, but not in auto. Wife put it in reverse the other day and returned the switch to auto. Without warning and no indication or man handling, it stopped running. (this is from a woman that breaks things with just a thought!). Either way, the unit should not have quit through normal or my wife's rugged use. HELP
Comments:
Mar 05, 2008
- Thanks. I went out and bought a new one.... $80 later
shedder runs then stops in the auto position, but wont accept paper when fed
Solution #2
posted on Mar 15, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hey - I had the same problem this afternoon with my Royal 15mx shredder which has served me well for several years. I tried the Q-TIP alcohol solution and my problem was solved !!!
Thanks a million !!!
You guys make researching things via the web community worthwhile !!!
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc board, contact manufacturer for more info.
Shredder SPL-1506x run but do not shred any paper and the overheat and overload come up any time a...
(More)
Shredder SPL-1506x run but do not shred any paper and the overheat and overload come up any time a tryed tu pass a paper
