Frigidaire FRS26R4A Side by Side Refrigerator
Problem for Frigidaire FRS26R4A Side by Side Refrigerator
Fridgedaire frs23lh5db1 ice maker not working
By sethtitley on Nov 08, 2009
fridgedaire frs23lh5db1 ice maker not working. this fridge is used and when i got it the green plastic line at the back of the fridge was cut and missing a 2' section of line. i spliced the line back together, hooked up the water ( i get water out the door now) plugged it in and flipped the ice maker bar to 'on'. after a few minutes i heard a noise that sounded like the 'pump' had kicked in and i noticed that the line to the ice maker at the back of the fridge had filled up with water. I waited patiently for 4 or 5 hours and when i went to check for ice there was none. I removed the ice tray and stuck my fingers in the ice maker tray and it was dry. i felt underneath the coils of the ice maker and burned my finger! I guess it has a coil to heat up so that the ice falls out and the cycle can start over. is the heat a malfunction or did the tray just fail to fill up with water? is something missing from the back of my fridge that ought to be there?
Popular Solutions for Frigidaire FRS26R4A Side by
Questions and Unsolved Problems for Frigidaire FRS26R4A Side by
Do you recommend Frigidaire FRS26R4A Side by Side Refrigerator?
Answer
Answer
have a side by side frigidaire refrigerator. the ice maker will only dispense ice cubes. it will not... (More)
Answer
THe paint around the ice/water dispenser if blistering and peeling. Can this be fixed?
Answer
I was wondering if there was a way to clean the trigger. Does it come off? How? My husband used a... (More)
Answer
ice maker stoped working & the switch is on the on position? not a top frig side by side...
Answer
I have a Frigidaire Model FRS26L85DW5 side by side fridge. Refrigerator works but freezer does not.... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in , MD
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
