I used to play online until one day the whole network in my house went down (i have wireless). My brother (who is a computer science graduate) fixed all the pc's and tried fixing the ps3 but couldn't.
I have tried everything putting all the network settings in manually and even copying them from my pc (so they must be correct) but it still wont work.
The peculiar thing is that it says it's connected giving a signal strength which fluctuates (so its ok) but when i try to open the internet browser even the homepage wont load, i cant sign in and therefore cannot play online.
(when i try open a webpage it gives error sayin "communication error with dns servers" but the dns settings are correct)
Please help me its been ages since i played online and friends are getting really annoyed!!!
Okay, i'll see if i know what we're talking about here. There are a couple of things you could try. For one, try logging into your router, (usually at 192.168.0.1 and looking in the Client or Address lists for a PS3, or whatever you have named it, and then see if you can either disconnect or renew it. Then, redo the whole WiFi setup on the PS3 setting all the settings as you would but leave the IP settings as they are (should be Auto). If that still doesn't work, go into the PS3's connection settings and manually set an IP address. My suggestion is to use the same address as an already connected (and working computer), but change the last number. Whatever you do, make sure there are not two of the same IP address on the router. Hope this helps...
i bought my ps3 in january 08 its a 40gb a couple of days ago i went to play it the sound is fine...
(More)
i bought my ps3 in january 08 its a 40gb a couple of days ago i went to play it the sound is fine but the picture is not coming up i took it to my neighbours and it didnt work on his telly either i think it might have something to do with the hd socket on my ps3 iv made sure the hd cable is in correctley on both my telly and my ps3 but it makes no difference im already getting withdrawal symptoms please help
Hi Im having issues with my PS3. Since the new update (3.1 I think) the PS3 does not save games...
(More)
Hi Im having issues with my PS3. Since the new update (3.1 I think) the PS3 does not save games (either auto or manual.) There also appears to be an issue with my profile, in that previous save games have been deleted. The BBC i Player has diappeared also. Please Help!!! Ive got to restart Fallout 3 because of this!!
my ps3 isnt even a year old and the controller is dead, it wont turn on even when conncected to the...
(More)
my ps3 isnt even a year old and the controller is dead, it wont turn on even when conncected to the cable
I can turn the PS3 on with the manuel switch. Then when I turn it on with the controller or the...
(More)
I can turn the PS3 on with the manuel switch. Then when I turn it on with the controller or the touch sensitive button on the front of the ps3, it will beep & the light will turn green as expected, but there is no flashing blue light & it won't actually turn on enough to function. There's nothing showing up on the television or sound. The screen stays as if I never touched the PS3 to begin with. Help?
