Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP 6110 All in one
I just "fixed" the head alignment because it got stuck but forgot where the absorption springs go back for the cover. I've spotted one side but where do these clip into the unit?
Need help setting up hp 6110 to my new computer.
Posted on Jan 17, 2008
Hp officejet 6110 all-in-one printer -- Getting error message "Press Enter to align cartridge." We've had this error before and did as instructed and it's corrected itself. However,...
turn off the printer
remove the cartidges.
Take a damp paper towel and clean the contacts of the cartridges and also the contact inside the holder of the cartridges.
put back the cartridges.
Print a self test
Also clear the the printer memory
Jul 25, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Changed cartridge in printer few weeks back - took several attempts to get cartridges to align afterwards. Now say to remove and check cartridge (appears to be problem with colour cartridge!). When put...
It might mean that your cartridge has become demagnetized. That happened to me and I had to replace the cartridge. The little brass covering at the front of the cartridge is very delicate and can become demagnetized if handled incorrectly. You can buy refurbished ones on line and they are not as expensive, but that is entirely up to you. Good luck.
Jan 05, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Press Enter To Align Cartridges
open the cover, make sure your cartriges are properly seated. it will proabably still ask you to re-align the cartriges. all this does (usually) is print a page and then ask you some questions about thw eay that page printed.
also, try turing you printer off and back on. (resatarting your PC with you printer may also help somehow, but that's pure unfounded speculation based on the experience that restarting the device usually fixes it...).
Jan 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Cartridges wont align
Could be one of two things....
1 - as the person has already posted, you may have bad cartridges...when the machine does an alignment it looks for specific marks on the paper...ie..green check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Inkworks
866-381-0541
Nov 04, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Alignment test keeps failing.
Can't over ride..has to be replaced..
Inkworks
866-381-0541
Jul 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Another Alignment Question
"paper too narrow" error is usually the spot sensor.
Inkworks
866-381-0541
May 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Align cartriges message continuously displayed
Here's the deal with the cartridge alignment page....the machine will spit out a series of black lines mixed with yellow ink and at the beginning of each of these lines is a "Green" check mark. The carriage moves back and forth over these lines and green check marks and reads them by use of what is called a "spot sensor" that resides on the right side of the carriage assembly. This is usually noticed by the blue ray of light that shines out of it. So if you are getting an alignment failure one of two things is happening....1)You've have got a bad cartridge (usually the color) and it is not laying down the right colors, specifically the green check mark or 2)You've got a bad spot sensor...even though it may still be shining the blue light, the sensor board can't process the information. Its an easy fix either way.
Inkworks
May 25, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer alignment
Inkworks
Apr 25, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Alignment
Inkworks
Apr 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
