Question about Sony PlayStation Portable (PSP) Console
Psp Was updating psp with the new 2008 madden game when the battery fell out. Now the green light comes on for about half a minute and nothing else. Tried the same game in next psp and it made the screen go black, turned off game and it came back on.Taking game back to store. Still don't know what can be done to maybe reboot the psp?
  • 263 Answers
Re: psp
Http:// if you follow this address you can find anyting to fix the psp ones you fix this rate me as a fixya
Posted on Jan 06, 2008
0 characters
3 Points
My psp fell and the battery pack fell out when I put the battery back the psp green light and sound of the game came on but the screen is plack and if I put it on and press R it still doesn't come on....
You most likely damaged the sensor that create the images on the screen. As for fixing it, it is fixable but it will be pricy. I would shop around and see how much they would charge to fix it because buying a new one might be more beneficial depending on what model you have.
May 26, 2011 | Sony PlayStation Portable (PSP) Console
My battery fell out while updating my psp, now the green light comes on but the screen stays blank!
Probably because some of the data got corrupted.
To reset to factory defaults (which is what I recommend doing), turn off your psp, hold start+select+square+triangle and then turn on your psp.
It should now boot up normally but with no data on it.
Apr 19, 2010 | Sony PSP (Piano Black)
Psp wont turn on
you have BRICKED your psp!! good thing there are ways around way is Pandora. it will work for psp PHAT or SLIM (not 3000+)
Jul 17, 2009 | Sony PSP-3000 Silver Console
While im plaing my psp, the screen freezed and i restarted it, when i turned on my psp (theres a green light) nothing happens the screen is empty then a few minutes the green light gone what happened
I guess you have custom firmware. If so, you can use a pandora battery to solve the problem. If you do not know how to make a pandora battery or if this doesn't work send me an email or add me on But pandora is most likely to be the solution. I had the same kinna problem but I was updating it thats the only difference. The green light is on and the screen was blank and then the light turned off. So I used a Pandora Battery and it fixed. :P
May 24, 2009 | Sony PlayStation Portable (PSP) Console
Psp 2001 custom firmware update error
My sons psp was used and it work when we got and now the green light comes on but wont stay on. Also no picture comes up on the sceen. How do i know if i need a new battery?
Dec 25, 2008 | Sony PlayStation Portable (PSP) Console
Sony psp wont turn on anymore after update
this is a common problem with psp`s you have what they called "bricked" your psp you can have it unbricked by some one with a pandora battery and a memory card.
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
yep, re update your psp, right now it is corrrupt or not complete. if there is a way to reset the psp (like a reset button) try that first.
May 22, 2008 | Sony PlayStation Portable (PSP) Console
Update problem with psp
Dec 28, 2007 | Sony PlayStation Portable (PSP) Console
If the PSP works correctly when the power adapter is plugged in but not when just running on battery then yes, you need a new battery.
Also triple-check that your PSP's screen brightness is turned up all the way (hardware buttons along the bottom of the screen.)
Dec 18, 2007 | Sony PlayStation Portable (PSP) Console
Psp updateing
Try undoing the update/firmware.
Aug 30, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
62 people viewed this question
Top Sony Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
