Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Problem for Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright...
The brushes will not rotate on my hoover vacuum.
By chulette on Nov 08, 2009
the brushes will not rotate on my hoover vacuum. the belts are in good shape, the motor is turning the vacuum motor, but the belt on the brushes seems loose. I ordered a replacement belt but still nothing. Their is a small "idler" but their dosent seem to be enough tension on the belt. Any ideas?
Comments:
Nov 08, 2009
- yes, the old belt and the new one are the same.
Solution #1
posted on Nov 08, 2009
Not Rated)
Vac Belts
Rank: Wiz  Vacuums  Expert
Rating: 80%, 61 votes
Did you order the correct size of belt? These are the belts you should have:
Hoover Windtunnel Belts
Was this helpful?
Yes
No
Popular Solutions for Hoover U6437-900 / U6439-900
Questions and Unsolved Problems for Hoover U6437-900 / U6439-900
Do you recommend Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum?
Answer
Answer
i have ordered the part and recieved it but don't know where to start to replace it.the handle... (More)
Answer
how to replace Self-Propelled Actuator Pivot Arm for hoover wind-tunnel 12 amp u6434-900
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover U6437-900 / U6439-900...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
