My washer appears to have a short in the control panel. Stops during some cycles, and doesnt work on the cold water choice. However, if i press hard on the panel, the cold will begin to fill the drum. I cant figure how to open the panel to see if its simply loose wires. Thanks
For a Kenmore 90 Series, on both sides of the control panel exterior, on the corners, there are plastic end-caps. Gently pop them off. Underneath you should see a philips head screw, one per side, where the control panel and washer top meet. Remove each screw and then pull the control panel up from the bottom. It should just flip up on it's hinges. Don't loose the screws.
washer does not start. filled up with water but then stopped. Attempted to unplug and plug. still...
(More)
washer does not start. filled up with water but then stopped. Attempted to unplug and plug. still did not start. Have taken clothes out but water is still in there.
kenmore 00622991 in the spin cycle the tub rachets and makes loud noise, the tube is turning every...
(More)
kenmore 00622991 in the spin cycle the tub rachets and makes loud noise, the tube is turning every time it rachets about 3 inches.
