Home | Hitachi | 51F500 51 in. Rear Projection HDTV-Ready Tel... | Colour separation on scr...
Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
Problem for Hitachi 51F500 51 in. Rear Projection HDTV-Ready...
Colour separation on screen
By chrisandlaur on Nov 08, 2009
on-screen picture shows separation and "offset" of blue and yellow colours.
Solution #1
posted on Nov 08, 2009
Not Rated)
SD Tech
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 97%, 854 votes
This model uses two convergence IC's----if 3 D one or both are bad.
Most of the time this set uses either two of the STK-392-110 OR THE STK-392-150 CHIPS.
Both chips and any bad protection resistors around them need to be replaced and the set adjusted.
If you are able to do the repair yourself total parts cost will be under 30 dollars.
Some history for you:
This set like all rear projection tube type sets uses two chips---the ones in your set are Black in color--about 2 1/2 inches wide X 1 1/2 inches tall and are on either one large or two smaller heat sinks with fins on them.
When the chips are installed a white grease called heat sink compound is applied to the metal back of each---the grease transfers heat from the chip quickly to the metal it is bolted to.
After some years the grease dries out from the heat and one of the chips goes instantly.
You can buy a pair of the chips for your set on Ebay for less than 15 dollars plus shipping--
If you cannot do the repair yourself--shop around your area---most shops charge 300-400 for this type of repair. Whoever you get to do it make sure BOTH chips are replaced or you will have the same problem in a few months.
If you open the set and locate the chips---they will have the full STK number printed on them in white letters----there are about 12 resistors around them that need to be looked at--if any are discolored they need to be replaced.
If a shop says it HAS TO GO TO THE SHOP keep looking as any good tech can do this repair right in your home in about 1 hour---I know as I have done hundreds of them.
IF you can solder and are handy I will give you general instructions on how to do the repair and what you need---some people I talk to can either do it or have a friend who can do it for them---let me know
I can tell you what you will need aside from the parts and how to proceed with the fix---
If all this helped rate this solution---I do this here for free.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE LET ME KNOW--I am here to help people.
Regards, SD TECH
Was this helpful?
Yes
No
Popular Solutions for Hitachi 51F500 51 in. Rear
Questions and Unsolved Problems for Hitachi 51F500 51 in. Rear
Do you recommend Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television?
Answer
Answer
Hi my TV model #51f500 looks orange and the color won't adjust please help
Answer
VS 60- 120 tool carousel. Remedies required for unreliable single arm cam box. Ours keeps breaking... (More)
Answer
Turned on the TV today and the images on the screen are separating. It looks like im looking at 3-d... (More)
Answer
I have a blue line going thru the center of the screen. I have done the magic focus tune up but it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 51F500 51 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
