Eureka Capture Upright Vacuum Vacuum
Problem for Eureka Capture Upright Vacuum Vacuum
Not sucing
By yumi13 on Nov 08, 2009
It is not picking up anything from the floor, and nothing is going into the bin.
Solution #1
posted on Nov 08, 2009
Not Rated)
Vac Belts
Rank: Wiz  Vacuums  Expert
Rating: 80%, 65 votes
The reason it is not picking up is probably because the belt is stretched, worn or broken and is not turning the brush the way it should and therefore not picking anything up. You should change the belt on your model at least once a year. Here is a link to the belt you need and a link to the owners manual which has belt changing instructions:
Eureka Capture Replacement Belts
Eureka Capture Owner's Guide
Was this helpful?
Yes
No
Popular Solutions for Eureka Capture Upright Vacuum
Questions and Unsolved Problems for Eureka Capture Upright Vacuum
Do you recommend Eureka Capture Upright Vacuum Vacuum?
Answer
Answer
how do i change the bag? or something it is smelling bad and not picking up well, help?
Answer
I am looking for a replacement part for a piece that feeds debris into the canister.
Answer
We have a Eureka Capture. The power is on, but the suction is not working. It is not vacuuming the... (More)
Answer
Just stopped in the middle of use. Only had it about a month. Switch won't activate at all.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Eureka Capture Upright Vacuum...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
