Home | Dell | Latitude D620 (D620SINGLE) PC Notebook | What would cause my D62...
Dell Latitude D620  PC Notebook
Problem for Dell Latitude D620 (D620SINGLE) PC Notebook
What would cause my D620 to not post most of the time?
By mate1_email on Nov 08, 2009
What would cause my D620 to not post many of the times I try to turne it on? I have to try repeatedly and eventually it will post but it can take MANY times turning it on
Solution #1
posted on Nov 08, 2009
Not Rated)
bob_computer
Rank: Guru  Dell Computer Hardware  Expert
Rating: 87%, 1184 votes
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Was this helpful?
Yes
No
Solution #2
Not Rated)
ithinkcomput
Rank: Master  Computer Hardware  Expert
Rating: 52%, 3 votes
You can try resetting your memory, and CPU with new thermal compound like Artic Silver 3.
Dell also has have many recalls on these units because of a defective NVidia graphics card. They are not factory recalls; they are recalls with swaps usually if the user is in warranty. Most companies like HP will extend the purchased warranty by 1 year because of this known defect.
Was this helpful?
Yes
No
Popular Solutions for Dell Latitude D620 PC
Questions and Unsolved Problems for Dell Latitude D620 PC
Do you recommend Dell Latitude D620 (D620SINGLE) PC Notebook?
Answer
Answer
how do iconnect headset with 2 jack plugs for acer 7540 i cannot get sound through headset could you... (More)
Answer
i can't conect mi mouse and the web camera in my lap top
Answer
When typing it will suddenly jump lines or even worse highlight a section and delete it. It happens... (More)
Answer
Hi ! sir i have a fly cell phone. i have used since 2&1/2 years . the battery is not working... (More)
Answer
If an administrator can't tell you there password reset there password.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Latitude D620 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
