Question about GE JGBP26 Gas Kitchen Range
My ge gas range will not heat up
My oven will not ingnit or heat up but my broiler and top burner work fine. When I turn on to bake I hear a relay click but the ignitor does not glow.
How can I verify this is a ignitor problem and where can I find a replace part with remove and replace instructions?
  • raybbr Dec 04, 2008
    What should the resistance be when read by the meter?
  • 525 Answers
Inspect the ignitor for a crack or break in the continuity of a ceramic ignitor. If you can't visually discern a failure, then a multi-meter is need to check for resistance through the ignitor.
Posted on Jun 02, 2008
Bake does not work
you need to call a repair service we do not recommend DIY with gas appliances.Safety reasons
Nov 02, 2017 | GE JGSP23 Gas Kitchen Range
Oven won't light
Ignitor, it is very rare that the regulator goes bad
Jun 06, 2012 | GE Kitchen Ranges
Oven won't heat, glow/igniter lights but no flame. Broiler will ingnite All burners work, Probable cause?
if you can hear gas when turned on then its likely to be a faulty/dirty burner. No gas flow then its the thermostat or dependant on model a faulty gas relay/valve
Dec 22, 2009 | Whirlpool Kitchen Ranges
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Oven will not heat up.
eerb, most likley your ignitor failed. When you turn the oven on to bake you should hear a relay click on the electronic control (clock). You can do a couple of things here. If you have a ohmmeter the ignitor should ohm out at between 50 and 150 ohms. You can physically swap out the bake and broil ignitors to see if the ignitor comes on in bake. Or you can swap the bake and broil wires on the board. They should be marked BA and BR. This way when you turn on bake, the broil ignitor should glow and verify you have power going to it. Carefull when testing, be sure to kill power to the range before any changes. back
Dec 12, 2006 | GE JGBP26 Gas Kitchen Range
Open Questions:
GE JGBP26 Gas Kitchen Range Logo
251 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
