Home | Apple | iPhone Smartphone | IPhone Road Runner Iss...
Apple iPhone Smartphone
Problem for Apple iPhone Smartphone
IPhone Road Runner Issues
By tagjack on Jan 05, 2008
I recently purchased an IPhone and am having trouble sending and receiving e-mails from my Road Runner account. I have confirmed that the pop-server and smtp-server information for Road Runner is correct, but still have no success. Any help help is greatly appreciated.
Same Problem
Apr 13, 2009
-   I can receive mail - but cannot send any.-   Guest
Mar 15, 2009
-   i can receive my roadrunner emails but cannot reply to them! help1-   Guest
Mar 01, 2009
-   I setup my RR email account on iPhone using
pop-server.roadrunner.com for outgoing
smtp-server.roadrunner.com for incomming
When using WiFi I have no problem sending and receiving. When using 3G only I can only receive emails. I get the following error when sending any emails "Cannot Send Mail The sender address was invalid"
-   tzori
Nov 29, 2008
-   I have the same problem with Road Runner (Time Warner). I verified (several times) the pop server was correct as well as the SMTP server info was correct. I went back to the AT&T store and they told me that TW does not support email to the iPhone. I then called TW (twice) and they confirmed this. Also they tried to refer me back to apple. The representative asked me "who is the manufacture of the iPhone? TW supports SPRINT as they are business partners. Anyway, to keep it simple I could not get the simple settings to work on my iPhone to get my RR email. I followed the advice of setting up a "Gmail" account and had my RR email forwarded. That works just fine. I am a little taken back by TW though! Just because they do business with SPRINT doesn't mean that everyone else wants to! -   Kmoen
Aug 26, 2008
-   thanks!!! I created a GMAIL Account and went to the RoadRunner WebMail page and checked the box that allows forwarding to GMAIL and keeping a copy at RoadRunner.
That is a really klugey way to solve the problem - but, hey, it works great! Thanks VERY MUCH for the information-   4thandLast
Best Solution
posted on Jan 11, 2008
Helpful)
applgeek
Rank: Wiz  Apple Expert
Rating: 88%, 55 votes
Try putting another email account on it. I suggest making an account at gmail and putting it on there. If it works, forward your roadrunner email to the gmail account and use that on your iphone.
Also, do you use pop or IMAP?
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 27, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Forwarding through Gmail is a solution however there is a slightly different, but I think better solution. You should have no problem receiving mail on your iPhone from Roadrunner, but sending out wo't work unless you're on your home network. Here's how to fix it.
1) Setup a Gmail account and add the account to your iPhone
2)In the email setting on the iphone navigate to your Roadrunner account settings. Assuming your incoming mail is working, leave the Incoming Mail Server Settings alone.
3)In the Outgoing mail server dialog enter the host name (smtp.gmail.com), Under user name enter your Gmail user name NOT your Roadrunner, and finally enter your Gmail password in the password field.
4)You've got mail
The reason it works is because once you've setup a Gmail account you have access to the server via your username and password. There's the added bonus of Gmail saving copies of any mail you send from your roadrunner account. BTW this technique works for any pop accounts you might have.
Hope this helps someone. =)
Solution #3
posted on Sep 02, 2008
Helpful)
mssully
Rank: Apprentice
Rating: 93%, 8 votes
Mine works now. Here is what I have.
under my mail account:
on mail account - now i have the new ipone g3 (do not think it matters)
incoming:
pop-server.tx.rr.com
my email & password
outgoing:
Primary server
smtp.server@tx.rr.com
advanced:
authentication password (your rr email password you must have this input for outgoing too)
Use SSL on
primary server smtp.server@tx.rr.com
other server at&t smtp server ON
att server was already set @ cwms.com (i could not modify this area) other than on/off
Hope this works for you!
I am a happy camper! :-)
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #4
posted on Jan 23, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The problem is that RR does not allow relaying. Level 2 Apple support told me so. The cwmx server is the old EDGE SMTP server for cingular, at&t. NOT for wifi use. You would think that Apple & Time Warner would come up with a solution ASAP! *I've had 2 clients with this issue. Yes, forwarding is a semi-annoying "fix" at best. IMAP mail is much more preferred if you have email AND mobile email.
Solution #5
posted on Jan 15, 2008
Helpful)
gator wood
Rank: Apprentice
Rating: 85%, 2 votes
I just got off the phone with Apple. They told me that the pop servers at road runner will only send the email to one place (your iphone OR your outlook). So I setup a gmail account and then went to the roadrunner webmail and set it up to forward to the gmail account. Tadaa! It works perfectly. Thanks for the suggestion applgeek!
Was this helpful?
Yes
No
Solution #6
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem. I called Apple. There is a completely different server for road runner accounts, for outgoing mail. It is something like smtp-cwmx (not the same as the one on your computer), but I would call your provider to make sure. Once I entered the new info under settings, it worked well.
Solution #7
Somewhat Helpful)
Chotty
Rank: Apprentice
Rating: 81%, 4 votes
RR email does not support relaying. that is the problem. Many unhappy iPhones users out there, Apple & att!!
Was this helpful?
Yes
No
Solution #8
posted on Apr 27, 2009
Very Helpful)
sbertling
Rank: Apprentice
Rating: 100%, 2 votes
With Roadrunner mail the outgoing server settings vary depending on wether or not you are processing the mail through your Roadrunner suppied modem or not. If your iPhone is connected through your Roadrunner modem (i.e. you are connected to your home wifi network) the SMTP server is set to port 25. If you are outside of your home network the SMTP server is connected through port 587. You can create an additional SMTP server and name it Roadrunner:587 (the colon will tell the setup to use port 587) and enable both servers. That way if you are at home and connected through your wireless lan (much faster than 3G) it will use the port 25 enables server and if you are on the road it will use the port 587 server.
Hope this helps....Enjoy
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #9
posted on Mar 16, 2009
Very Helpful)
hmshapiro
Rank: Apprentice
Rating: 97%, 16 votes
Setting Outgoing Server on iPhone
1. From the Home screen, tap Settings.
2. On the Settings screen, tap Mail, Contacts, Calendars.
3. On the Mail screen, under Accounts, tap your Roadrunner account.
4. Tap Outgoing Mail Server (SMTP).
5. Tap Primary Server (might say, smtp-server.roadrunner.com or some other rr server)
Host Name
Change Host Name to cwmx.com
User Name
Leave blank
Password
Leave blank
SSL
Make sure SSL is off
Authentication
Should say Password
Server Port
Should say 25, if not change to 25
As an alternate if the above does not work: After tapping Outgoing Mail Server (SMTP), look for AT&T SMTP Server, tap it, then turn Server to ON
Good Luck!
Was this helpful?
Yes
No
14 people thought this was helpful
Solution #10
posted on May 13, 2009
Somewhat Helpful)
eyumr
Rank: Master
Rating: 79%, 76 votes
Hi Friends,
Problem with Apple iPhone? Most of the iPhone problem is Unlocking problem.
If you want to unlock your iPhone now you must Click Here.
If you have any other problem with your iPhone you can try the site by Click Here. May the site can help you.
Was this helpful?
Yes
No
Solution #11
posted on Nov 25, 2008
Not Rated)
stest028
Rank: Apprentice
Rating: 0%, 0 votes
How to setup my email in iphone? im using xxx@nyc.rr.com
Incoming server
pop-server.nyc.rr.com
Outgoing server
cwmx.com
no username
no password
Unfortunately tWC is quite adimant about not allowing outgoing mail from off the Roadrunner network. So you cannot use the same settings as you would at home…
(for those following, that would be smtp.nyc.rr.com)
Also unfortunately, ATT will not allow anyone to use the CWMX.com server off the EDGE network.
What does this mean? You should use the cwmx.com server as much as possible, but it means that if you are off the edge network (on wifi) at that exact moment, your mail will not go out. Once you get off wifi (manually, or leave the range of the hotspot) your mail will send out.
Another way to do this would be to forward your email to google.com. Google’s interface is free, connects just fine, and will hold EVERY email there until you delete it. So you could forward your email to the gmail server, checking the setting to leave copy of mail in your roadrunner account. This will send a copy of the mail to google while leaving a copy at home.
Set up your iphone to it the gmail server (it has preset settings in the mail setup).
Was this helpful?
Yes
No
Solution #12
posted on Sep 14, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Have you tried solution #8?
Solution #13
posted on Mar 25, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have always heard that the relaying problem is the issue, but that you could fake it out by using a different SMTP port with password authentication. I will research more just because I'm like that. Thanks for the GMail suggestion as a fallback though.
Solution #14
posted on Mar 01, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I was able to make Solution 3 work. However, when I send an email via my Road Runner account, it has my Gmail address as the sender. Is there a way it can go out as my RR account?
Thank in advance
Popular Solutions for Apple iPhone Smartphone
Questions and Unsolved Problems for Apple iPhone Smartphone
Do you recommend Apple iPhone Smartphone?
Answer
Answer
purchased data plan for att for iphone, internet does not work
Answer
I want to open the the phone to remove the battery
Answer
I want to open the iPhone to remove the battery. Please tell how it is opened.
Answer
white screen with black lines on right side
Answer
when I go into my iphone e-mail, and try to compose or reply to someone, no keyboard appears, so i... (More)
10 Other Users Have The Same Problem - Continued
Comment by ekurtz1, posted on Aug 24, 2008
Can receive but not send from my road runner account. It worked fine at first and now will not work. Will not recognize server to send from road runner.
Comment by Guest, posted on Aug 15, 2008
AHHH, My friend just gave me her smtp and that worked fine. Now I can send mail However, I CAN"T RECEIVE Mail now. It says "cannot connect to pop-server@roadrunner.com." I'm usually on "edge" I;m ready to shoot someone!! Any help?
Comment by linkeylegs, posted on Jul 29, 2008
I have the exact problem and the battery is wearing down way too quickly. AT&T suggested that I get a new phone if the battery keeps failing. They said to contact Time Warner for the e-mail issues.
Comment by Guest, posted on Feb 18, 2008
Roadrunner doesn't seem to use IMAP only POP, thus problems using Iphone which requires IMAP
Comment by blessednc, posted on Feb 15, 2008
I can get my incoming roadrunner email but even with the AT&T smtp address cwmx.com I can't get my email to go out on my Iphone
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple iPhone Smartphone:
Top PDA Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
