Routers
Problem for Routers
Generic problem for all Routers
Can not access my ip address in order to ...
By brengolfer3 on Jan 05, 2008
I need to change my nat from strict to open for xbox live, but when i try to access my ip to change it it says not responding, example-- i type in 69.2.168.9 (my ip) to my browser and it says not responding, any help?
Same Problem
Mar 29, 2009
-   its like chika row
-   Guest
Mar 03, 2009
-   every time i type in my ip address it keeps sayin failed any one in dublin wanna set it up for me for a hundred euro -   dublinspud
Feb 08, 2009
-   I disabled my NAT (before reading this) in order to have a better connection on my XBox, however, now its stopped me from accessing my router - and I obviously i need to access my router in order to enable it again!!! Help! I have a Belkin router -   Sparbuck
Jul 25, 2008
-   i have strict nat and i need open but me and my friend dont knoe how to change it any suggestions?-   IHeadx
Best Solution
posted on Jan 06, 2008
Very Helpful)
BggFixya
Rank: Guru
Rating: 87%, 137 votes
Hi Brengolfter3,
My guess is, the IP to your router is still 192.168.x.x. Only way you are going to be able to get to the router, is to set your machine to a static IP, and then try to get to the router.
This site tells you how set it to static, http://corz.org/comms/hardware/router/static.ip.address.php
The IP you listed is assigned to Easton Utilites, so I have asume it is your internet IP. You might want to check the Xbox troubleshooting for the Xbox, so you don't have to disable your Nat, which is a firewall, by default. Good Luck!
Was this helpful?
Yes
No
Solution #2
posted on May 17, 2009
Not Rated)
oobligosh
Rank: Apprentice
Rating: 0%, 0 votes
i had the same prob, i just did a factory reset and it worked fine again, but i hadn't put many settings on it so it was easy to remember
Was this helpful?
Yes
No
Solution #3
posted on Jan 26, 2009
Not Rated)
thebadmojojo
Rank: Apprentice
Rating: 0%, 0 votes
assign your xbox a static IP address and then create the following forwarding rules to the statice ip address of your xbox.
The following ports must be available to your Xbox 360 console for Xbox LIVE to operate correctly: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
I have a dlink di-524, lost antenna, bought new one, I need the pice that connects the antenna to... (More)
Answer
I am trying to find the security key to add a wireless computer...have comcast and tired of staying... (More)
Answer
We got a Belkin wireless. Plugged into computer via eithernet line. Computer is on a Verison... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 3608
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
