Question about LG VX8300 Cellular Phone
Ph vx8300 how to unlck ph and make it work
    Problem Solver:
  • 10 Answers
Dial *22899 and wait until the phone goes through the auto programing once this is done your password will be the last 4 digits of your phone number
Posted on Jan 17, 2008
My security code has bean change and i forget it please tell me how to unlock this phone
6ya staff
SOURCE:
What pH levels are good for you?
The way that pH levels work is that a low number is bad, equal to 7 is neutral and more than 7 is good.
Jan 05, 2014 | Measuring Tools & Sensors
Tip
The procedures posted for the v-chip unlck doesn't work for me, rca 27f520t. any...
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works: Hold down MENU on the remote and VOLUME DOWN on the TV it?s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
on Dec 05, 2007 | RCA F27664 27" TV
LCD showing unlck and beeping
New or used? Or look for the unl key and press it down for 3-5 seconds on the beeping one. It could be a variety of problems, esp. if used.
Aug 01, 2012 | Chatterbox FRS X2 Communicator Two Way...
Only driver door unlcks when put in park,or locks when put in drive.
IF THE PASSENGER LOCK WORKS WITH SWITCH then the functions are set up for the drivers only to unlock read your owners manual and should tell you hoe to change settings
Apr 22, 2011 | 2004 Chevrolet Colorado
How to fix ph and hardness in my above pool
Best Answer - Chosen by Asker First of all, I would NOT recommend you use muriatic acid as some people mention, unless your pH or alkalinity are extremely high. This is highly dangerous acid, and if you put in too much, then good luck getting your pH back up again.
You need to test your water with test strips, a droplet test, or bring it into your local pool store and they can test it for you. They should tell you at least your alkalinity, pH, and chlorine levels.
You want to make sure your alkalinity is balanced BEFORE you balance your pH. Alkalinity and pH are related - if your alkalinity is not stable (stable generally means it's between 80 and 120 parts per million or ppm), then your pH will be jumping up and down.
Once your alkalinity is between 80 and 120 ppm, then work on balancing your pH. As long as your pH is between 7.2 and 7.8, it is within a good range. If your pH is 7.8 or higher, you can buy pH decreaser or pH minus at the pool store. On the back of the container, it will tell you how many grams to put in, according to how many litres in your pool. If your pH is extremely high, like at least 8.5-9, then you could consider putting in muriatic acid.
If your pH is too low, you can buy pH increaser or pH plus and put that in your pool. Again, the container will have helpful instructions on the back of it. pH increaser is basically sodium bicarbonate (aka baking soda) so if you're hard up for cash, I've heard of some people just dumping baking soda in their pool. However, pH increaser is definitely better quality so I would recommend that first.
It's really that simple. If pH is above 7.8, dump in some pH decreaser. If it's below 7.2, dump in some pH increaser. You can buy them for under 10 bucks each at many pool stores.
Aug 09, 2010 | Intex Automatic Salt Water System for ...
How to unlck the mouseo n a Compaq notebook PC
After doing some research on the net - google searched your issue - it seems like the most common fix is to turn your computer off, remove the power cable, and then remove the battery for about 5 minutes. See is that helps.
Aug 03, 2010 | Compaq Computers & Internet
How do I calculate pH from H+ concentration on a ti 30a? [H+] 1.2 x 10 -5 M = ? pH = 4.9 I worked out pH to concentration but struggling for the opposite figured it out once and...
You calculate the pH with the relation
pH=-log(c) where c is the value of concentration in mol/L.
ex: c[H+]= 3.57x10^(-6)
pH: (-) [LOG] 3.57 [2nd][EE] [(-)] 6 [ ) ]
Here you have 2 change sign key press [(-)]
If you have the pH, and want to calculate the concentration that yields that value of the pH you proceed as follows
c= 10^(-pH)
Ex pH=8.23
c: [2nd][LOG] [(-) 8.23 [)]
General shortcut.
If concentration is of the form c[H+]= 1*10^(-a) where a is an integer between 0 and 14, the pH is equal to the positive value of exponent.
Ex:c[H+]=1x10^(-5) Mol/L then the pH is just the positive value of the exponent, ie 5 because pH=-log(1.x10^-5) =- log1 -log(10^-5)=0 -(-5)=5
Above I use the rule log(axb)=log(a)+log(b) , the rule log(a^b) = b*log(a)and the facts that log(1)=0 and log(10)=1, the last being true if log stands for log in base 10.
May 20, 2010 | Texas Instruments TI-30XA Calculator
How can i unlck a sony t303 for free
You can't get free...You can get the unlock code here onlinegsmunlock.com and also get the unlock instruction in the same site....
Sep 14, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Unlck blackberry 8320 from t-mobile usa
You will need to use a service in order to unlock the BlackBerry. You need to acquire an unlock code either from your carrier, or a company that provides the codes (www.blackberryunlockingcodes..com recommended). Once you have the code they should also give instructions on how to unlock it.
Sep 11, 2009 | Cell Phones
I have a region 3 and would like to unlock, only have standard remote,
HI , I NEED UNLCKED CODE FOR SONY FX810 FOR ZONE 4 LATIN AMERICA, HAVE THAT?
Dec 22, 2007 | Sony DVP-FX810 Portable DVD Player
LG VX8300 Cellular Phone Logo
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
