Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
I was playing a game and I turned if off from the
By alvinwakefie on Nov 07, 2009
I was playing a game and I turned if off from the controller and when I turned it back on the red lights were flashing. It did that last week and i unplugged it for a few minutes and it started working again but this time its not working
Comments:
Nov 10, 2009
- I have three red lights flashing. Every time I turn it back on the lights still flash and it won't come on.
Clarification Request
Posted by Ravensvenom on Nov 08, 2009
How many lights?
Solution #1
posted on Nov 08, 2009
Not Rated)
cooke2518
Rank: Guru  Microsoft Video Games  Expert
Rating: 88%, 33 votes
e74 or rrod error means that there is an hardware issue.
What you need to do is a very simple and cheap repair.
look on ebay for x clamp repair kits, these are just a few bucks and most sellers include a good guide in how to do the mod/fix.
what causes the rrod or e74 error is the X shape clamp on the underside or the mother board bending and mis-shaping causing the ball soldering on the gpu/cpu slightly melting and forming hairline cracks in the solder.
The x-clamp kit will apply more pressure to the gpu/cpu and a little trick of disconnecting the fans and turning on the xbox and allowing it to overheat will re melt the solder ball joints to fill the hairline cracks.
Depending on which chip is the issue you may also need a 2000 watt heat gun instead of using the over heating method (the gpu chip).
Replacing the heat pads on the heat sink with thermal paste which comes with the kit will keep the gpu/cpu cooler and you wont have this issue again.
Please make sure you buy the kit which comes with heat treated nylon washers as the steel spring washes fail!.
The repair takes around 1-2 hours
I hope this helps in fixing you xbox.
Depending on how many red lights are flashing could indicate a different fault from the one described above to a dirty dvd lens error but your sounds like the one above
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
when using a game we cannot move to the right - we have tried changing games and controllers but... (More)
Answer
xbox 360 freez on two of my new games one same level jasper no lights lose controler function remove... (More)
Answer
it wont read disk but it sum times will read
Answer
I cant play bfbc 2 in xbox 360.WHY?i already puted mi email and pasword and it says that i... (More)
Answer
why don,t my hdtv setting hightlight so i can set it my xbox won,t work on hdmi cable
Describe your Video Game Consoles problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
