Pioneer GM-X334 Car Audio Amplifier
Problem for Pioneer GM-X334 Car Audio Amplifier
Pilot light on unit is flashing rapidly, no
By mtnwrks2 on Nov 07, 2009
pilot light on unit is flashing rapidly, no apparent output
Clarification Request
Posted by skinnman33 on Nov 10, 2009
Sounds like it is going into a protection mode. If you have the manual take a look at it and sometimes in the problem section it will tell you what the different flashes mean. Also if you could say what happend prior to the problem or did it just happen all of a sudden. Check all connections also, like your main power and ground going to the amp. Try unpluging the RCA's and speaker wires to see if there might be a floating ground externally. If it continues to have the same problem than it's internal and could be a few different things from the power supply section having some shorted mosfets or the output section having some transistors shorted. Don't really know until you eliminate a few things as I described to narrow it down to an internal problem. Let me know what you find so I can better assist you.
Solution #1
posted on Nov 25, 2009
Not Rated)
catally733
Rank: Guru
Rating: 90%, 5 votes
disconnnect speaker wires , if amps light is steady then its one of the speakers or wireing . if not check ground ,or use a meter to check rca barrel to amp for ground set meter @ rx1 ,see amps ground is solid and clean
Was this helpful?
Yes
No
Popular Solutions for Pioneer GM-X334 Car Audio
Questions and Unsolved Problems for Pioneer GM-X334 Car Audio
Do you recommend Pioneer GM-X334 Car Audio Amplifier?
Answer
Answer
i was driving down the road and the adio just shut off on my kvt911dvd. no noises or electrical... (More)
Answer
i cant figure out my amp wire color code
Answer
what are the specs on amp model la2259 ..no power from amp and wanted to check resistance
Answer
do not change 1 to 2 velocity in manual shift or automatic D1
Answer
hi, I have a citroen synergie 2lt hdi with a webasto cooling system heater and would like to find... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Amplifier Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
