Whirlpool Duet GHW9150P Front Load Washer
Problem for Whirlpool Duet GHW9150P Front Load Washer
I get a message 2 F now it is completely locked up
By sdkuipers on Nov 07, 2009
I get a message 2 F now it is completely locked up cannot open door. Just keeps flashing 25 min.
Best Solution
posted on Nov 08, 2009
Very Helpful)
jsrock516
Rank: Guru  Whirlpool Washers & Dryers  Expert
Rating: 96%, 6780 votes
"F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. In most cases this means there is a clog in the drain pump. Before assuming the pump has failed, you can easily clean the trap. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. A new pump (if required) can be purchased on line at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
These pumps are easy to install and can be accomplish by the average Do-It-Yourselfer without the assistance of a repairman. If you need to replace the pump, the following link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful.
Comments:
Nov 08, 2009
- If the door is jammed and will not unlock, you can use the manual release to open the door to retrieve anything left inside. The following link explains:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Nov 08, 2009
- "F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. BEFORE assuming the pump is bad, in most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
Replacements can be purchased at any of the following websites:
repairclinic.com
This is a simple repair that any Do-It-Yourselfer can accomplish with ease. The following link explains how:
If the door is jammed and will not open, you can still retrieve anything that may be stuck in the unit by using the manua release. The following link explains:
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
EllaWatson25
Rank: Wiz  Whirlpool Washers & Dryers  Expert
Rating: 84%, 110 votes
This is your pump that has gone out on this unit.
We are Whirlpool factory authorized service and parts suppliers and canget the correct part out to you asap.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We would like to get your washer back up and running again soon.
We are at your service from 7 AM until 9 PM CST Mon – Sat!
Thanks, Ella :>)
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Duet GHW9150P Front
Questions and Unsolved Problems for Whirlpool Duet GHW9150P Front
Do you recommend Whirlpool Duet GHW9150P Front Load Washer?
Answer
Answer
the washer wont even turn on is there a rest button or some things i can try to do a quick fix?
Answer
How do I turn off the "control lock" on my Maytag Epic front loader...my child was playing... (More)
Answer
washer stopped working yet makes sounds like it is trying. the drum is not moving and water is in... (More)
Answer
My duet is not spinning fast even though it is on the highest setting
Answer
my washer faults at the end of the final cycles and i have to reset a couple of times for it to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool Duet GHW9150P Front...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
