Kenmore 62602 Electric Dryer
Problem for Kenmore 62602 Electric Dryer
Kenmore electric dryer will not get hot, what's
By beethea on Nov 07, 2009
Kenmore electric dryer will not get hot, what's the problem?
Solution #1
posted on Nov 07, 2009
Not Rated)
hansola
Rank: Wiz
Rating: 84%, 10 votes
Usually there is a part called the heating element that causes the clothes dryer to heat up so the clothes dry. It is an electrical part, usually it is 220 volts, so unplug FIRST before worhing on it. Need to remove the back panel to access it. It's usually only about 20-30 bucks, most generic appliance stores will be able to sell you one. It's not a big deal to replace or time consuming but different makes place it differently.
Hope this helps!
Was this helpful?
Yes
No
Solution #2
Not Rated)
salde386
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 93%, 48 votes
check the heater pull one of the wires off and read out the heater with a meter if it's good read out the thermostats on heater box and on blower housing
Was this helpful?
Yes
No
Popular Solutions for Kenmore 62602 Electric Dryer
Questions and Unsolved Problems for Kenmore 62602 Electric Dryer
Do you recommend Kenmore 62602 Electric Dryer?
Answer
Answer
i turn the dryer on and then hold the button down so i can look inside and whatch the heat elements... (More)
Answer
model 110.66912692 will not start....can hear timer, but when i push start nothing
Answer
Kenmore 90 series gas dryer won't start. Model #11072912100. Light comes on inside. What should I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 62602 Electric Dryer:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
