Panasonic Lumix DMC-LZ2 Digital Camera
Problem for Panasonic Lumix DMC-LZ2 Digital Camera
Lens won't go in, seems to be zooming in and out,
By jhunter39 on Nov 07, 2009
Lens won't go in, seems to be zooming in and out, then a message appears on screen, "Please turn camera off and then on again." I've done this and it still doesn't correct the problem.
Best Solution
posted on Nov 08, 2009
Helpful)
BillB-SA
Rank: Guru  Cameras & Camcorders  Expert
Rating: 85%, 373 votes
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Panasonic Lumix DMC-LZ2
Questions and Unsolved Problems for Panasonic Lumix DMC-LZ2
Do you recommend Panasonic Lumix DMC-LZ2 Digital Camera?
Answer
Answer
I've Got Lumix FZ28 camera.... when i shoot in wide angle mode it shows a black spot on left side of... (More)
Answer
display screen black.... will take photos however you can't view them (hence cant see what your... (More)
Answer
Shows error that my camera is stuck between modes.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic Lumix DMC-LZ2...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
