Question about Sharp VL-H875U Hi-8 Analog Camcorder
SHARP VL-H875 PROBLEMS
HI! I am having a problem with my Sharp Viewcam Model VL-H875. When I insert an 8mm tape and close the cassette door, the cam attempts to play (the picture on the screen is frozen momentarily) and EJECT begins to flash on my LCD screen. I had it stored for about 6 months prior to just taking it out to watch home movies, and it worked fine when I packed it away. I tried many different 8mm recorded cassettes, but I get the same error EJECT each time I insert another one in. I cannot find a manual anywhere online for this model. Have any ideas or suggestions or know where I can find a replacement manual for this thing? Sharp's customer service is aweful! Tried calling many times and the hold time is rediculous. THANK YOU!!!!
otacon
  • 1944 Answers
SOURCE: Sharp video camera VL-AH50
Did you try cleaning the tape head?
Posted on Feb 22, 2008
SOURCE: VL NZ50U
hello i have a probleme like you with my VL DP3S
First you must cleaner the head with a cassette cleaner 5 sec max. if it's not ok you must consulting a specialist
Posted on Dec 22, 2008
  • 1335 Answers
SOURCE: Sharp Viewcam VL-AH151U keeps saying "eject cassette"
Assuming the record tab is in the correct position, download the manual for the VL-AH150U, very close to the 151U.
Page 10 of the manual shows the normal reasons for the "eject cassette" message. If not, I would call Sharp support at
1-800-BE-SHARP (237-4277) for referral to a local repair center.
Let me know if this helps.
Posted on May 03, 2009
Testimonial: "Thank you very much!!!"
telstarservi
  • 95 Answers
SOURCE: what type of cassette do i need for a sharp VL-A10
You need to use a tape that says 8mm or Video8 only. I have provided a link to the type of tape that we would use.
http://www.amazon.com/Sony-MP-Video8-tape-120min/dp/B0009WUCG6/ref=sr_1_7?s=electronics&ie=UTF8&qid=1284056100&sr=1-7
There are tapes that say Hi8 and Dig8 on them. These tapes will not work properly in your camcorder because they are the wrong format. Your camcorder would probably chew the tape at some point if you tried to use this kind.
Hope this has helped.
www.austintelstarservices.com
Posted on Sep 09, 2010
tbreeze47
  • 3083 Answers
SOURCE: I have a Sharp Viewcam
The chances are that a switchcontact or motor is not engaging, and the unit will have to be opened up to be fixed.
Oftentimes, with these older units, switch or relay contacts become oxidized over time, and fail. It sounds crazy, but one fix (without having to open the camcorder) is to give it a bump with the palm of a hand. I used to do withis with my old Olympus, and that's the only way I could get it to work, without spending a few hours taking it apart.
You can always go by a tv or camera repair shop and see what they think. Get an estimate before having it repaired, since it might be better just to upgrade.
You can contact Sharp for support here:
http://www.sharpusa.com/CustomerSupport.aspx
Good luck, and hope this helps.
Posted on Jan 02, 2011
I have a sharp 8mm viewcam vl-e33 it plays only part of the recorded tape. There are two "ribbons" across the view screen that do not play video.
i need the t.v attachment to camcorder 8mm vl e33 dont know where to get it ,,already try it on ebay...but nothing
Feb 19, 2013 | Sharp Video Cameras
What type of cassette do i need for a sharp VL-A10 viewcam 8
Sep 09, 2010 | Sharp Viewcam VL-A10U Camcorder
Cassett does not get inserted
Put a head cleaner tape in camera and run it for 20 seconds ever few months.
May 29, 2010 | Sharp Viewcam VL-Z1U Mini DV Digital...
I have an old SHARP Viewcam 8mm analog camcorder. It's one of the first models. I bought it in Japan in 1994. How can I transfer/convert my analog 8mm tapes to my computer? My Toshiba Satellite L100 does...
if you do abit of searching your bound to find a websight with a converter of some kind, or you can also go to most large electronic retailers, and by a converter
(p.s, hears a website, not sure how good it is though, hav'nt tryed it! http://labnol.blogspot.com/2006/06/convert-audio-cassette-tapes-to-mp3.html
Apr 18, 2010 | Sharp Viewcam VL-AH151U Camcorder
I have a sharp 8mm camcorder. i have a tape that just plays the audio and not the video. HELP
there is differnt quailtitys in the 8mm tapes, i knwo there is a real HQ one that if its used int he standard 8mm cam corder you will only get audio from it. hope this helps in some way.
Nov 30, 2009 | Sharp Viewcam VL-AH151U Camcorder
Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Oct 18, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
8mm Cassette mechanism fails to eject or sometimes fails to close
This camcorder is at least six years old now, and replacements are available quite cheaply vie on-line auction sites, probably at far less than the cost of repair.
Apr 05, 2017 | Sharp Viewcam VL-AH60U Hi-8 Analog...
Sharp Viewcam VL-AH151U keeps saying "eject cassette" why is that? How or where can i send this to get fixed?
Jan 18, 2009 | Sharp Viewcam VL-AH151U Camcorder
The "DEW" indicator is illuminated on my Viewcam, what do I do to turn it off?
This means there is moisture inside the Viewcam. Try taking the tape out, leaving the cassette compartment open for 2 hours to allow any condensation to evaporate. If the DEW indicator is still illuminated call a Sharp authorized servicer.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Why does the Sharp Viewcam ® use the 8mm format?
At Sharp, we feel that 8mm is the best tape format available due to the small, compact size, long 2-1/2 hour record time, and high quality audio/video performance.
Sharp VL-H875U Hi-8 Analog Camcorder Logo
150 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
