Linksys Wireless-G Broadband Router
Problem for Linksys Wireless-G Broadband Router
Connection
By daltaloma on Jan 05, 2008
i am unable to access internet after programing cd and installing usb into computer wirless connection
Same Problem
Feb 16, 2008
-   yes i have the same problem-   Guest
Jan 05, 2008
-   I could connect fine to the internet through my modem..then put my daughters router on board and her lap top works great..but my desk top cannot connect to internet even though it says it is connected. The AIM things comes up but yahoo will not. It has to be something to do with connecting through the router instead of straight from the modem.Any suggestios?-   Guest
Solution #1
posted on Jan 06, 2008
Not Rated)
carywinton
Rank: Guide
Rating: 84%, 18 votes
Yes I have a suggestion, here is what you need to do.
1 Make sure your new router is connected to the Ethernet port on the DSL/Cable Modem, you never specified which type of modem you have, if I knew this information I could assist you even more accurately. Your PC should be connected to the new router also on one of the Ehternet ports, they usually have 4. You need to verify your computer (PC) is getting the DHCP information from the new Router(Linksys) This can easily be determined using this command in az DOS window. If you are using Windows XP, again you did not specify your PC's OS, go to "Start", then "Run" and type in "cmd", withouth the quotes.
This will open a DOS window. In this window type "ipconfig /all"
The important thing to look for here is your Network cards IP Address, Default Gateway, Primary and Secondary Domain Servers Addresses. These should nearly match your daughters information, except for the IP address, whcih will be close but the last number(s) will be different. Most of the time the problem is due to both the modem and the router are on the same network and are both running DHCP, which is what gives out the IP address, default gateway and DNS information for your PC and your Daughters to use for Internet access. It could also be that your PC has the same IP address as her's, whcih will cause the exact problem you are discribing as well. If you turn off her laptop and can then access the Internet on your PC, then this is exactly what is happening. You will then need to make sure the Linksys Router and the DSL/Cable Modem are on a different network, by changing the address of one or the other, it is easiest for you to probably just change the Router. It is problably set to 192.168.1.1 or 192.168.0.1 Hook your PC directly into the modem again. run the command "ipconfig /all" and look at the IP address it gives your PC. If this is the same as the one your Router is giving, then you have found your problem. Unplug from the modem an again plug straight into the router, nothing else. Open a web browser and type in http://192.168.x.x whatever the IP address is for the default gateway that is shown on your PC. You should get a login window. By default Linksys usually uses admin as the username and password, consult your manual to be certain. In the web page that opens, your manual can help you further here as well, there should be a "Setup" link you can click where you can change the "LAN" network IP Address. You only need to change the 3rd number, as in 192.168."X".1 If the modem was 192.168.1.0 for example change the Routher to 192.168.2.0 and you should be fine. Please let me know if this has helped or if you need further assistance.
Was this helpful?
Yes
No
Popular Solutions for Linksys Wireless-G Broadband
Questions and Unsolved Problems for Linksys Wireless-G Broadband
Do you recommend Linksys Wireless-G Broadband Router?
Answer
Answer
none of the lights that show the line is working are lighting up when i plug lan into router
Answer
can't find roku.com/link to enter code
Answer
Zyxel P 600 .... need to change to full bridge
Answer
the pogo game I,m having trouble with
Answer
find or your down find it for today afternoon got it GGGGGGGGGGGGG
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Router Experts
Top Computer & Laptop Repairmen
in , CA
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
