Unfortunately this is a common problem on the PS3 and is caused by a fault with the laser pick-up in the blue-ray drive. The unit will have to go back to Sony for service.
You could try a DVD cleaning disk first to be sure that dirt on the laser lense is not causing the issue.
You can also open the case and clean the laser lense with a Q Tip and an alcohol cleaning solution.
If you plan on opening the case at any stage please ensure the unit is disconnected from its power supply.
If this fails and you are confident with electronics there are several videos on YouTube showing how to replace the drive if you choose to order it and do it yourself.
Otherwise I believe Sony are doing these on an exchange basis for around $150 if your unit is out of warranty. You can contact Sony customer support at this link if you need to do this.
I can't get my AV multi to work properly on my PS3. It works fine when the HDMI is connected, but...
(More)
I can't get my AV multi to work properly on my PS3. It works fine when the HDMI is connected, but when I switch to A/V all i hear is sound. I tried reseting it about 7000 times, and i tried switch the settings to a/v multi out on the PS menu. Is My A/V multi output broken?
I have a PS3, i want to play online games. I press multiplayer and it says go to network settings....
(More)
I have a PS3, i want to play online games. I press multiplayer and it says go to network settings. It still doesn't connect and it then says that the internet connection has timed out
between 30% to 42% signal with NETGEAR WNR854T RANGEMAX NEXT WIRELESS-N CABLE ROUTER GIGABIT...
(More)
between 30% to 42% signal with NETGEAR WNR854T RANGEMAX NEXT WIRELESS-N CABLE ROUTER GIGABIT EDITION. I'VE TRIED ALL CHANNELS AND STILL THE SAME WEAK SIGNAL APEARS
On my PS3 when I try to connect the PS3 to the Internet, It keeps saying that my IP Address keeps...
(More)
On my PS3 when I try to connect the PS3 to the Internet, It keeps saying that my IP Address keeps timing out. Help
