Mitsubishi WS-55859 55 in. Rear Projection Television
Problem for Mitsubishi WS-55859 55 in. Rear Projection Television
42kl Mitsubishi TV problem picture
By m_ziifle_fol on Nov 07, 2009
42" Mitsubishi Projection TV Model WT42311 has wavey picture with top and bottom areas separating colors. Could it be one part? I was watching when TV just started having problem picture.
Solution #1
posted on Nov 07, 2009
Not Rated)
asnowman
Rank: Guru  Televisions & Videos  Expert
Rating: 96%, 554 votes
What you might be experiencing based on your symptom sounds like a damaged convergence IC.
With any Projection Television that has a damaged convergence IC, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these
Was this helpful?
Yes
No
Solution #2
Not Rated)
SD Tech
Rating: 97%, 906 votes
If you go into the customer menu and select CONVERGENCE--look to see if red and blue will adjust or not---if skewed and will not adjust:
This set uses 2 of the STK-392-110 convergence chips--18 pins each.
BOTH WILL NEED TO BE REPLACED AND ANY DAMAGED RESISTORS AROUND THEM LOCATED AND ALSO REPLACED---most of the time just the chips need to be replaced.
This is a fairly easy set as with the back off and one plug unplugged the entire "box" inside with everything comes right out.
Let me know if you want to attempt this and I will tell you where you can get the chips for less than 14 dollars plus shipping.
I am here to help people--if this information helps you rate this solution as I do this here for free.
If you have questions or need more help let me know.
SD TECH
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-55859 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55859 55 in.
Do you recommend Mitsubishi WS-55859 55 in. Rear Projection Television?
Answer
Answer
Mitsubishi WS-55859. HD antenna works fine. Standard antenna and all other video inputs have sound... (More)
Answer
I lost the audio from my DM board I get audio from all my other imputs. My tv is a WS-55859... (More)
Answer
I have a Mitsubishi 55 inch ws-55859 rear projection tv with no sound from my ANT-DTV but when I go... (More)
Answer
SD Tech mentioned that he had detailed instructions on how to solve the 2 blinks short protection... (More)
Answer
When I try to turn it on, the green light comes on for a few seconds but it turns off again. I was... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-55859 55 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
