Leaking water on the left front side of the freezer door - automatic ice maker is not working...
(More)
Leaking water on the left front side of the freezer door - automatic ice maker is not working properly
Roper RT18BKXKQ00 to much moisture from diffuser. have to put glass under diffusers to catch drops...
(More)
Roper RT18BKXKQ00 to much moisture from diffuser. have to put glass under diffusers to catch drops of water.
I have a GE Profile Side by Side, model PSS25NGN AWW. I have the temp
in the fridge side set to 37...
(More)
in the fridge side set to 37 degF, but it is cooling down to around 30
degF and is freezing the food. I adjusted the temp control to 42 degF,
but it doesn't help. The fridge will still cool to around 30degF.Any
idea what is wrong? Is the thermostat bad or is there a dood between
the fridge and freezer that is staying open and allowing the cold air
from the freezer to get into the fridge side?Thanks
I have been having a problem with my fridge for a couple of months, the evaporator in the ref keeps...
(More)
I have been having a problem with my fridge for a couple of months, the evaporator in the ref keeps freezing up and creates alot of ice build up. A tech came out and replaced thermistor, the damper, and the temperature control, but still no solution. HELP ME PLEASE !!!!!
