Cuisinart Grind and Brew 10 Cup Coffee Maker - Black and Stainless Steel
Problem for Cuisinart Grind and Brew 10 Cup Coffee Maker - Black and...
My Cuisinart 10 cup Grind & Brew does not
By wahubbell on Nov 07, 2009
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only about 9 months old.
Best Solution
posted on Nov 08, 2009
Helpful)
Sassy6
Rank: Guru
Rating: 89%, 116 votes
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Cuisinart Grind and Brew 10
Questions and Unsolved Problems for Cuisinart Grind and Brew 10
Do you recommend Cuisinart Grind and Brew 10 Cup Coffee Maker - Black and Stainless Steel?
Answer
Answer
The program light comes on immediately after plugging in machine and then blinks repeatedly. I can't... (More)
Answer
on off light stays on but does not brew. opened face, noticed moisture and slight burnt elec smell.... (More)
Answer
my grind and brew coffee maker has developed a problem in the last two weeks, when making coffee it... (More)
Answer
I have a la marzocco swift grinder and the tamper does not go up again? any idea what the problem... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
