Canon PIXMA iP90 Mobile Printer
Problem for Canon PIXMA iP90 Mobile Printer
Color tank isn't installed --- but it is!
By koznut on Nov 07, 2009
I'm trying to print and the error message says "The following tank is not installed Color Ink Tank. Install the ink tank properly and close the printers cover. If you do not want to install the ink tank, click Cancel.
I've done this a couple of times and even tried a new ink tank. I printed a couple of months ago with no problem.
Comments:
Nov 07, 2009
- I promise I'm not trying to be dense, but what is a ticker?
Solution #1
posted on Nov 07, 2009
Not Rated)
randyprevost
Rank: Wiz  Computer Hardware  Expert
Rating: 81%, 167 votes
Printer messages can be very confusing at times. Based on what's written here, I understand it to mean that you have the option of printng without the color ink tank needing to be installed, and clicking 'Cancel' allows you to do so. Is this correct?
Is this message appearing because the ink tank is missing, or because the printer cover is open? Or both. Is anything preventing the printer cover from closing properly? Have you tried performing a Self-test/Nozzle Check?
Here is some important information. Check that none of these exist, or have taken place:
  • When a tank is replaced, the ink counter must be reset.
  • Use an ink tank within six months of its first use.
  • Once an ink tank has been used, do not remove it from the printer and leave it out. This will cause the ink tank to dry and the printer may not function properly if it is reinstalled.
  • Color ink consumption may occur even when black-and-white or grayscale printing is specified.
  • Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer's capabilities.
  • When a tank is empty, replace it immediately. Printing with no ink in the ink tank may cause problems and, the Low Ink Warning dialog which tells the exchange time of an ink tank cannot be indicated properly.
Hope this helps.
Randy
Remember to rate this solution and mark it solved when applicable.
Was this helpful?
Yes
No
Solution #2
Not Rated)
alenorm
Rating: 85%, 169 votes
Make sure that all tickers are off from the tank and clean the housing good and run self clean first and reset the printer
Comments:
Nov 08, 2009
- sorry sticker on the tank usually they have plastic cover very small you can not see,, but the main thing is that you have the housing clean good use a cotton pad and some cleaning to clean the inside especially the contacts and do same on the tank, then run the selfcleaning that should work and let me know sorry again
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA iP90 Mobile
Questions and Unsolved Problems for Canon PIXMA iP90 Mobile
Do you recommend Canon PIXMA iP90 Mobile Printer?
Answer
Answer
how do I clean the waste ink absorber on a cannon ip90
Answer
i have a canon ip90. i just replaced the colour cartridge as it was low. there was a problem before... (More)
Answer
how to clean the canon ip90 waste ink absorber?
Answer
How can i change or empty the ink waste absorber?
Answer
I think I have to replace my ip90 printhead. The colors print fine but no black ink. I'v had it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA iP90 Mobile...:
Top Printer Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
